2 batteries 1 alternator
Can this be done. First reason is im running an underdrive pulley and and amp that has a little draw. The second battery I would use for headlight connection,door connections or whatever else. When I did the new engine I saved some weight. I took off all smog including the fuel canister which is where the new battery will go.
Re: 2 batteries 1 alternator
If you're trying to save weight, adding a second battery isn't going to help. Dump the under drive pulleys as they don't add any power.
If you truely want to be able to charge 2 batteries, you're going to need an isolation circuit to do it.
If you are having charging issues from an underdrive pulley, adding a second battery will make matters worse. pulleys are crap, you'll never feel the 5hp and they couse charging and overheating (on other cars) issues. Either install a smaller pulley on the alternator or put the stock pulleys back on.
The only way I would recomend a second battery is if you have a mondo huge stereo. Then you will also need a battery isolator and to remove the UD pulley as the alternator will need all the RPM it can get to properly charge both batteries.
Re'
Re'
tommalcolm
Sep 11, 2015 03:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
