Just got nitro, whats the 411?
Old Oct 5, 2006 | 01:37 AM
BlackBird97's Avatar
Hey guys, I just got an NX Kit, i'm just wondering all the basics. I have a window switch, bottle opener, heater, and everything else.
-What should I set the window switch for an A4-
-What should I do with the bottle when I store the car-
-All in all how basically do you use everything, I know a little bit but not everthing. Gentlemen, ENLIGHTEN ME!-
Thanks guys!
Old Oct 5, 2006 | 10:00 AM
Moshbmx1's Avatar
Re: Just got nitro, whats the 411?
Welcome to the nitrous craze.
I have my window switch set at 3000-5900 rpm. Id recommend not spraying before 3000 rpm. Also, do you have any way of pulling timing when you are on the bottle?
Basically how the nitrous actually gets into the intake, is first the system must be armed, bottle on etc. Then if you are running a WOT switch then it must be at WOT and at or above the set window(3000-5900rpm). Once that happens the computer must see adequate fuel pressure if you are using a fuel pressure safety switch, then if all goes well it should plant you firmly in the back of your seat
As far as storing the bottle, id say just take it out of the car and make sure it has some nitrous in it as it will turn into air over time but you dont want your bottle completely empty for the whole winter.
Old Oct 5, 2006 | 10:38 AM
sprayedtransam's Avatar
Also, nitro and nitrous are not the same thing
Scream And Fly
Aug 4, 2004 11:40 AM
buickman68
Jun 28, 2004 04:44 PM
buickman68
Parts Wanted
Jun 18, 2004 10:49 PM
LT1Z28
Pacific
11
Jun 1, 2004 08:11 PM
Kevin97ss
Advanced Tech
35
Apr 13, 2004 04:19 PM
