How much Rwhp should I expect with this set-up
Old Sep 23, 2006 | 03:03 PM
detroit1994z28's Avatar
Okay currently I have a 94 camaro z28. I also have the STS turbo system with the t-67 upgrade. Basically the engine is stock with just the lt4 hot cam. I made 400/408@7psi. I wanted to know how much rwhp I should be around with the boost turned up to 8psi. LE2 heads, matching ported intake, turbo cam from Lloyd Elliott. I was talking to Lloyd and he told me around the475/500rwhp range. I was just wondering what you guys thought I would be around.
Old Sep 23, 2006 | 03:38 PM
jerminator96's Avatar
Re: How much Rwhp should I expect with this set-up
Sounds about right, with really rough math anyway.
Lloyd knows his stuff, and I would take his word for it anyday
Old Sep 24, 2006 | 01:16 PM
LT1runner's Avatar
nevermind.
Old Sep 24, 2006 | 11:02 PM
TransAm396's Avatar
im gonna say..a good...3k in an engine rebuild
Old Sep 25, 2006 | 08:24 AM
I think he will be fine for a good while. Go get a gallon of Toluene with every tank of gas and you'd never have to worry about it
Old Sep 25, 2006 | 09:46 PM
slomarao's Avatar
with 9.5.1 comp it should last for a while. How many miles are on the shortblock? 475-500rwhp is a lot for the an lt1, most or some guys make it for a while with 400rwhp with a FI setup. 6psi is considered the safe limit, but it's really not. Lots Lt1's go at pressure. I would take it easy inless you want to rebuild it.
As for the numbers, llyod's predictions are some of the best your going to get. Your car should be right there. good luck
Old Sep 25, 2006 | 09:48 PM
TransAm396's Avatar
His engine will have the same characteristics as TRI-NITRO tolene
Old Sep 25, 2006 | 10:10 PM
Rodrigues's Avatar
469.7 rwhp!
Old Sep 26, 2006 | 12:34 AM
C7H5N3O6 makes some good power, albeit in all the wrong directions
Old Sep 26, 2006 | 12:35 AM
TransAm396's Avatar
haha you know what it is?
Old Sep 26, 2006 | 08:11 AM
Yeah man, cars may be my life but chemistry is still a hobby
I'd try to run on a tank full of Hydrizonium Nitrate if I thought I'd live to tell about it.
95chwagon
Oct 16, 2015 12:24 PM
drt
Sep 27, 2015 04:39 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
