When shutting off engine, how do I get the IAC to park not fully opened?
Old Sep 23, 2006 | 01:56 PM
2QUIK6's Avatar
At idle before I shut the car off, the IAC steps are at around 25...immediately when the engine is shut off, they go to 130. So at startup the next time, the IAC is already open 130 steps and it revs high upon startup, I don't want it to do this.
I changed the IAC PArk vs Coolant Temp all the way down to 10 for all positions, but it has no effect on where the IAC parks at shut down.
Anyone have any ideas?
I tried to figure this out a few years ago with no luck.
Old Sep 27, 2006 | 12:29 AM
Josh'95Z28conv's Avatar
Re: When shutting off engine, how do I get the IAC to park not fully opened?
I would imagine thats supposed to be that way. More air for starting. Otherwise it would be hard starting.
Old Sep 27, 2006 | 11:46 AM
2QUIK6's Avatar
Maybe, but I'd at least like to turn them down and see what happens, I can always crank it back up if need be...
Guess I could back the stop screw back out which will raise the IAC counts at idle back up real high which would be closer to where its parking at when I cut the motor off to see what the effect would be.
Old Sep 28, 2006 | 02:44 PM
Sweetred95ta's Avatar
Backing the stop screw out will open up the blades and the IAC counts will go down, not up.
Old Sep 28, 2006 | 05:18 PM
2QUIK6's Avatar
Depends which side you're looking at when you say "backing the stop screw out" I'm thinking of backing it out by the rear of the TB where the screw head is, which will close the throttle blades.
Old Sep 28, 2006 | 05:32 PM
Ah, I gotcha. I adjust mine the other direction.
oldschool
Feb 9, 2016 09:21 PM
Alex Barnes
Jan 24, 2015 10:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
tds1213
Nov 27, 2014 12:55 PM
centric
Aug 15, 2002 09:04 PM
