Throttle Body won't fit with TNT plate?
Old Sep 12, 2006 | 08:38 PM
F(ast)-body's Avatar
seems the bottom of the throttle body hits the thermostat housing once you put the plate on....I have a BBK 58MM so it's a bit bigger than stock...I doubt I'm the first person to run into this....how much grinding did you guys have to do and how much is "safe"?
Old Sep 13, 2006 | 02:21 PM
Mr_Bond's Avatar
Re: Throttle Body won't fit with TNT plate?
You have to grind alittle off the housing and some of the TB bypass. It should fit fine then.
Old Sep 15, 2006 | 12:49 AM
Built LT1's Avatar
I had my kit installed and they informed me of the grinding that was required in order to install the package. I am sure that if you grind only enough to make it work it should be fine. TNT would probably know best as the design is theirs and they are aware of this step.
Old Sep 15, 2006 | 02:22 PM
Nitro Dave's Avatar
You also have to grind in order to install our plate. It is a very tight fit.
Dave
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
