Did a camaro come with a 12 bolt from factory
Old Sep 6, 2006 | 09:32 AM
RickS's Avatar
This guy at my college is trying to tell me that some 3rds cam with a 12 bolt from the factory, i dont believe him, is this true?
did they ever use a 12 bolt? i would guess mabie the TTA but other than that...
Old Sep 6, 2006 | 11:19 AM
RE AND CHERYL's Avatar
Re: Did a camaro come with a 12 bolt from factory
Nope...Never....WHY???
The third gen in stock form was a turd. Why would it need it. The TTA used the same 10 bolt as everthing else. GM NEVER put a 12 bolt in ANYTHING production after the early to mid 70s.
This of course don't include one off freaks and vehicles built to abuse drive train compunents.
Old Sep 6, 2006 | 11:29 AM
89TramsAmGTA's Avatar
From 1985 through 1989 some 3rd gens came with the stronger nine bolt rear end made by Borg Warner. Otherwise they came with the 10 bolt.
I don't know this but maybe some first gens with the 396 motor came with 12 bolts.
Old Sep 7, 2006 | 11:27 AM
I was under the impression that the 9 bolt was even weaker than the 10 bolt.
The 12bolt was an option with the SS package with the SB or BB. I beleive it was standard with the BB M4 cars.
Old Sep 7, 2006 | 12:02 PM
Jcrane88's Avatar
the Borg warner units were made from 1987-1990 and they were posi..although there were some posi 10 bolts as well
Old Sep 7, 2006 | 04:04 PM
IROC-T's Avatar
That would be a G80, or G92 package.
Old Sep 7, 2006 | 06:34 PM
jms's Avatar
jms
They were available 1985 through early 1990 model years.
Not all were posi. I have personally seen a 3.08 non-posi 9-bolt with drum brakes under a 1985 T/A.
Also, the 9-bolt is/was stronger than the 10-bolt. Not a bunch, but enough for GM to consider it the upgrade rearend.
The TTA used the 9-bolt.
For more info, check www.thirdgen.org
jms
Old Sep 7, 2006 | 09:07 PM
Right, the nine bolt is stronger than the 10 bolt. Some say close to the Dana 44 axle. You can buy the TA rear cover to make it even stronger. The cost was the reason the nine bolt was dropped.
Old Sep 12, 2006 | 02:22 PM
guywidiroc's Avatar
I have over 500 passes launching nitto drags and bf drags on my 9bolt. It is a beast!! 5,000 rpm dumps with heated bf drags and nothing has ever broken.
It is a real strong unit from my experience.
Old Sep 12, 2006 | 08:28 PM
89Vert's Avatar
Originally Posted by robvas
9 bolt is much stronger than the 10 bolt. Good lucking finding parts and the gear ratio selection stinks.
parts are easy to find, axles have to be custom made, 3.27, 3.45 and 3.70 are the common gears,
I got 1 of each
MadMav
Feb 6, 2015 11:02 PM
ddr698
Jan 9, 2015 10:05 AM
UT Trans AM
Nov 15, 2006 11:20 AM
97QuasarBlue3.8
Jul 22, 2002 09:09 AM
