Any SPL rides here???
Old Sep 2, 2006 | 06:16 PM
lil305gta's Avatar
Post pics of your db mosters....what subs are you guys running? Who's hit 140+???
Old Sep 3, 2006 | 04:41 PM
bt96ss's Avatar
Re: Any SPL rides here???
I have a trophy here that I got for winning a local SPL contest. Meter read 145.3. At the time I was running a single Image Dynamics IDMax in a medium size ported box. It was powered by a Xtant 1001DX. It was more bass than I really wanted in a daily driver so I stepped down to a Zapco 500.1. It is not near as loud but still might be on the verge of 140. I have built quite a few camaro/firebirds with Kicker gear that are in the 140's. I think if you build a good ported box, use two quality 12's and at least 1000 watts 140's is doable.
Old Sep 3, 2006 | 05:44 PM
lil305gta's Avatar
Have you know anyone to hit 140 with a dual or triple sub set up in a sealed box? With the space limitations how did you port the box?
Old Sep 5, 2006 | 12:39 PM
rickyzZ28's Avatar
Off the front windshield I hit 150.? This was many years ago. I have 4 Comp VR 12" in a sealed box, bridged. I am running a Kicker ZR-600 amp putting out ~900 watts. Pics are on my site if it is working.
Old Sep 5, 2006 | 01:11 PM
lil305gta's Avatar
Ricky....how many cubic feet was that sub box? Is each one sealed off from the others? Did you have any dynomat?
Old Sep 5, 2006 | 01:24 PM
bt96ss's Avatar
The largest box I have had in mine is roughly 5.5 cuft internal space ported. It had three PBX 12s off two soundstream 501\ strapped. Can be seen a Hi-tekcaraudio.com in the install section. I later switched to a single Solo X in 3 ft ported off a Kicker KX2500.1. Thats the loudest shystem I have had so far. I never got it metered though. You can get pretty good airspace in the well and on the package area without removing the plastic side pieces.
Old Sep 6, 2006 | 08:05 AM
rickyzZ28's Avatar
Sorry I do not remmeber the specs of the box. It basically is as tall as the back seat and goes down into the hatch area. My box is filled with polyfill which I bought at jo-ann fabrics (they call it pillow stuffing ). Much cheaper and works just as well. The box is sealed side to side, meaning that the 2 speakers on each side are in the same box. I built a partition into the box to help with the sound. I had originally planned to port the box, but changed my mine when I switched from 4 regular Kicker Comps to the VR series. The reason mine hit so hard off the windshield is because the box is angled and the sound travels like a big arc to the front of the car. I have tried to put the mic directly over the subs (in outlaw class) in other competions and have hit less dbs so I stick with the off the windshield method.
Also my car has no dynamat or any other sound fill except in the box.
WPHIG2
Aug 27, 2015 06:37 AM
NewsBot
Aug 21, 2015 07:20 PM
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
KYWes
Aug 10, 2015 07:03 PM
