Abs inop and low traction light on?
Old Sep 2, 2006 | 02:56 PM
camaro95owner's Avatar
Hello i have a 95 z28 and when i drive the abs inop light comes on but the brakes are fine and also when i apply the brakes and i am almost to a full stop the brake pedal will fall a little bit and the low traction light comes on but the car does stop. I dont know what is the problem. Any advice would be helpful. Thanks.
Old Sep 3, 2006 | 12:19 PM
OBE1 95Z28's Avatar
Re: Abs inop and low traction light on?
I had this issue; the rear ABS sensor that's mounted in the top of the differential got dirty. Remove and clean the sensor.
Old Sep 3, 2006 | 04:58 PM
Alright thanks ill try that monday.
Old Sep 5, 2006 | 05:30 PM
I pulled out the sensor on the diff in the back and the sensor was clean, so now what do i do?
Old Sep 5, 2006 | 06:07 PM
Dave89IROC's Avatar
your center brake light good?
if it is, you need to get the codes pulled from the ABS module(EBCM/EBTCM)
Old Sep 5, 2006 | 06:36 PM
KillerTA's Avatar
What kind of scanner do you need to get the codes? Do they loan it out at Autozone?
Old Sep 5, 2006 | 08:21 PM
Dave89IROC's Avatar
you need one of the more expensive ones(mastertech, tech 2 , ect.), AFAIK, they don't have them at autozone
Old Sep 6, 2006 | 05:43 AM
So i would have to have my mechanic check for codes right?
Old Sep 6, 2006 | 06:03 AM
Dave89IROC's Avatar
yes
Old Sep 6, 2006 | 02:28 PM
Alright thanks ill keep you updated with what code i get.
Old Sep 6, 2006 | 08:36 PM
Severous01's Avatar
did you clean the sensor or just look at it? if you didnt clean it, spray it with brake cleaner or electronics cleaner. most likely it has small metal shavings on it since it is magnetic
Old Sep 7, 2006 | 04:41 PM
Actually when i looked at it, it didnt have any metal shavings at all.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
