383 stroker
Old Nov 13, 2002 | 02:45 AM
99huggerorangeZ's Avatar
Question 383 stroker
i just bought a new block with a 4.000" bore and i cant find a forged piston in that bore with 1/16 , 1/16, 3/16 ring width
i called speed pro, scoggin dickey and looked on JEs website and i dont see a single forged 4.000" piston
i dont want to bore the block because there is no need because it is a new block
does anybody know where i can get either a speedpro/TRW forged piston or a JE forged piston for a 4.000" bore
i need to stay between 9.5:1 -10.5:1 CR
i have a Eagle 4340 forged crank 3.750 (350) mains
Eagle H beam 5.7in rods
federal moguel rod and main bearing
but no PISTONS
PLEASE HELP
Old Nov 13, 2002 | 06:19 AM
rskrause's Avatar
JE and the other racing manufacturers will make you a "custom" set, no problem. You will pay a bit more than for an "off the shelf" pisotn though.
Rich Krause
Old Nov 13, 2002 | 06:42 PM
95CamaroZ-28's Avatar
I would just call the manufacturers, I'm sure they can take care of you. BTW, a 4.000" bore with a 3.750" stroke is a 377. Sounds like a nice setup though. Should be a pretty stout bottom end.
Quickss96
Jan 29, 2016 05:56 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
