Is there a "quick change" or Nascar rear end.
Old Aug 31, 2006 | 09:25 PM
93z383's Avatar
Thought I hear about Steve Foose (sp?) installing a "nascar" rear end in a camaro. Whats the good word, anyone heard of this. Good bad ugly?
Old Sep 1, 2006 | 01:46 AM
Soccerbum21's Avatar
Re: Is there a "quick change" or Nascar rear end.
i've heard of it, but really, what would you really need a quick change rear end on a street car or a drag car?
you can easily dial in the gears on a ford 9" for much cheaper i think
but http://www.wintersperformance.com/ has quick change rears and there will be a good bit of custom work involved to make it fit properly but anything can be done with the right amount of welding
Old Sep 1, 2006 | 04:23 AM
wdtiger's Avatar
Yes, a place called Speedway Engineering in Sylmar, CA makes quick change rear-ends. The late model dirt car i crewed for had one (actually, most of them do). With a little practice, it's possible to change the final gear ratio in less than four minutes. I do not know if these are what the NASCAR boys use, but i'm sure it's something like it.
Old Sep 1, 2006 | 06:12 AM
FastLt1's Avatar
Seems like the pinion comes out really low. Angles would be worst then 9 inch.
Old Sep 1, 2006 | 08:44 AM
Wckd94Z's Avatar
don't they whine quite a bit too?
Old Sep 1, 2006 | 11:02 AM
FirstYrLS1Z's Avatar
Nascar uses the 'Ford 9" ' style rearend.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
