Brakes Squeeking....while driving, not when i apply the brakes.... help!
Old Aug 24, 2006 | 01:29 PM
CamaroRacing12's Avatar
hey guys ever since i put on my new MB Drifters and painted my calipers i have been getting this really annoying squeek from apparently all 4 wheels.....but the thing is when i apply the brakes it stops...... what can i do to fix this?
Old Aug 25, 2006 | 05:44 AM
Sean94Z's Avatar
Re: Brakes Squeeking....while driving, not when i apply the brakes.... help!
Take the pads out and coat the back side of them with anti-seize where they touch the calipers. Also put anti-seize on the sliders while you have them out.
Old Aug 25, 2006 | 03:25 PM
ABA383's Avatar
Also check to make sure that your calipers are centered over your rotors...If not they will make contact while rolling and it will still stop when the brakes are applied...I had to shim mine out a hair with washers when I installed my Strange rear...Sounds like a similar noise...
--Alan
Old Aug 25, 2006 | 05:18 PM
wait lol ima lil confused....shim wat??? i am sorta new at it so be very specific lol....yea that sounds like wat it is....cuz everytime i apply the brakes it stops.....it never use to do it before until i put new rims and tires on and painted the calipers.....i painted them on the car and it wasn't the cleanest job....but im pretty sure i didn't move the caliper much....u shimmed the caliper?
Old Aug 25, 2006 | 05:59 PM
ABA383's Avatar
Yes...My Strange rear has caliper backing plates on the rear...When we mounted my stock calipers they were not exactly centered over the rotor and the outboard side of the caliper was rubbing on the outside of the rotor...When the brakes were applied the pads were pushed in by the caliper and the noise stopped...I had to put about a 1/32-1/16" washer between the caliper and the mount to move the caliper outward a bit which centered it over the rotor...no more noise...I know you didn't change rears, but sometimes the aftermarket is not as exact as the OEM stuff...
...and I could see the marks being left on the rotor and see the contact while turning the wheels while on a lift...just something to look at...
--Alan
Old Aug 25, 2006 | 06:57 PM
yea but this dosent just happen when i turn...its a continous squeek unless im braking....
Old Aug 25, 2006 | 07:07 PM
ABA383's Avatar
It won't matter if you're turning...I meant spinning the wheel slowly while its on a jack or lift...Just check real carefully that the rotor is not contacting the caliper....
--Alan
Old Aug 26, 2006 | 10:08 PM
k i will try that thankyou!
Old Aug 27, 2006 | 01:43 AM
NoRiceInside's Avatar
my fronts do it. i took the pads out and saw that the sides are grinding into the caliper. seems to be the wrong pads (well correct pads, poor fitment...stupid autozone).
Old Sep 1, 2006 | 11:12 PM
PROBLEM FIXED!!! i fixed it by sanding down and removing the rust on the edges of the rotor inner and outer...... then wipped it clean and applied brake lubricant to all the edges.....i believe it was just rust build up on the inner lip in the middle of the rotor that was rubbing agianst the inner pad.....a lil rust removial and a lil brake lube does the trick.....i recommend doing this to all 4 brakes if u have the wheels off..... just to keep them in good shape overtime...... thats wat im gonna do
Old Sep 2, 2006 | 11:49 AM
BMWKillR's Avatar
Yep. My gf bought the cheapest ones possible from them for her GMC Jimmy...I of course installed them, but the pads didn't slide in well. So, I had to file them down to make them work. They really are POS's
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Gtpguy
Jan 26, 2015 04:50 PM
Hurin
Dec 13, 2014 07:38 PM
