Torque arm click/thump
Old Aug 22, 2006 | 10:52 PM
NipNaZ28's Avatar
Hey guys, i installed my torque arm a while back and it clicks or makes a thumping noise when i go over bumps, or put it in reverse. it feels like its hitting up on the floor or something. But i checked all the bolts and everythings tight? is this normal? thanks guys
Old Aug 23, 2006 | 07:04 PM
2000GTP's Avatar
Re: Torque arm click/thump
Is it an adjustable torque arm? Do you have the pinion angle setting correct if so? Are the bushings properly lubricated? My torque arm has some additional noise and road harshness to it, but nothing to unbearable or extremely noticable.
Old Aug 23, 2006 | 08:02 PM
Severous01's Avatar
check the tranny mount....it's the most likely source. other than that check the TA mount on the tailshaft, that may be loose.
Old Aug 23, 2006 | 11:25 PM
NipNaZ28's Avatar
So the tranny mount where the old front part of the factory torque arm mounted needs to be intact? I'll check that out, thanks guys
Old Aug 23, 2006 | 11:45 PM
Dave '97 Z28 M6's Avatar
If you have a tunnel brace mounted torque arm, you can discard the factory front TA mount ("clamshell")... it's not needed.
Old Aug 23, 2006 | 11:51 PM
NipNaZ28's Avatar
I have a tunnel mounted torque arm the UMI one, but i still dont know where the sounds coming from. Like i said its a noticable thump or light thump sound when driving over bumps or potholes in the road, or when i put it in reverse it makes a louder noise. Not quite sure where its coming from but i can pretty much feel it on the floor under my seat where the tunnel mount is, it feels like.
Old Aug 24, 2006 | 10:06 AM
I'm about to install the same TA... one thing I noticed in the instructions: The bolts on the front link of the TA must be torqued at 40-50 ft lbs... that's critical since it's a pivot point.
But, you've got the same instruction sheet, so you've probably already done that. A floor mounted TA will introduce more noise and vibration into the interior of the car. Maybe what you're experiencing is normal?
Old Aug 24, 2006 | 04:42 PM
NipNaZ28's Avatar
well if you install yours and you notice a noise coming from the floor while shifting into reverse also i wont be worried, let me know buddy
Old Aug 25, 2006 | 09:51 AM
OK, will do. But my car's a 6-spd, so it may not be directly comparable.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
