problems with my "new" brakes
Old Aug 21, 2006 | 07:15 PM
darknessz28's Avatar
so a little over a month ago i put on all new pads and all new rotors...i went with rotorworks drilled and slotted rotors and got hawk performance pads from the ws6store....and now my right rear squeaks all the time...my mechanic told me it was my "aftermarket" parts....just wonderin if anyone has had problems with these....its bugs the s%^t out of me...thanks
Old Aug 21, 2006 | 08:18 PM
ABA383's Avatar
Re: problems with my "new" brakes
Check the clearance of the calipers and the rotors....I found that my Strange 12 bolt backing plates positioned my calipers off center to my rotors causing the outside of the caliper to rub the rotor...I had to space off the calipers with washers to move the caliper outboard slightly (maybe a 1/32nd-1/16th of an inch) to center it over the rotor...I know you didn't replace the rear, but the aftermarket is not as exact as factory...Just something to look at...
--Alan
Old Aug 22, 2006 | 06:35 PM
Greed4Speed's Avatar
Did you lube the contact points?
Old Aug 26, 2006 | 01:21 AM
no i did not
Old Aug 26, 2006 | 01:23 AM
Klypto's Avatar
my hawks always squeeked... lubed, and re lubed many times.. couldnt get them to go away.... and i had ALOT of dust off them... im sure it was a bad instance i dunno, heard nothing but good about them, but they just drove me nuts
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
