Engine misses when weather is hot & humid!
Maybe someone can help me brainstorm the possible cause? I have a misfire going on that only happens when it's hot & HUMID out. Ocassionally when it is raining also. When the miss isn't there, the engine runs perfect, and I have yet to get it to throw a code, even yesterday when it was missing badly. It doesn't do it as badly at light throttle as it does with heavy throttle. I have replaced plugs, wires, and ignition coils. I'm really having trouble figuring it out without a code. I'm over 100k miles, with the original cat, but I thought if they got clogged it would throw a code. Any ideas?
-John
-John
Re: Engine misses when weather is hot & humid!
I've checked them, and everything looks fine, but this problem persisted even immediately after putting on the new plug wires. Normally when I've had an issue with a plug wire it resulted in a code being thrown. Would a sticky injector throw some sort of code? The miss is more than noticeable, but still no code!
teedoff59
Aug 8, 2002 01:36 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
