Torque converter problem
Old Jul 30, 2006 | 03:39 PM
Jeff95TA's Avatar
I installed the torque converter onto the transmission, but it doesn't want to spin freely, it keeps binding and you can hear grinding inside.
It should spin freely on the tranny, correct? Might have to send it back for repairs.
Old Jul 30, 2006 | 06:42 PM
12SCNDZ's Avatar
Re: Torque converter problem
You've got 3 possibilities. Something is wrong in the transmission pump, pump bushing, or as you suspect...something is wrong in the converter. It should definitely spin free. Did you buy the converter from a reputable manufactuerer? You might want try reinstalling your original converter to see if you encounter the same problem.
Frank
CPT
Old Jul 30, 2006 | 10:57 PM
Jeff95TA's Avatar
I hate to say it but I think I screwed it up. In my haste to get everything done today I started to snug up the housing bolts before checking to see if there was clearance between the converter and the flexplate. I think I didn't get all the "clicks" when putting the converter on and ended up putting pressure on it. That's what I get for hurrying.
I'm going to try the old converter like you suggested.
Old Jul 31, 2006 | 06:22 AM
12SCNDZ's Avatar
Aaaahhh. I thought you had this problem initially. I didn't know you had tried bolting the trans. up. In that case, I'd say you've broken the pump rotor.
Frank
CPT
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
