Second Time at the Track with my 96 TA what do you think?
Old Nov 11, 2002 | 12:21 PM
96 TA's Avatar
Like the topic says, this is only my secound time at the track (1/8th)with my 96 TA. What do you think? Bad? Good? my power mods were
induction: SLP Timing Ticker
SLP CAI
exhuast: Hooker LT
Mufflex off road y-pipe
Hooker Catback
Susspenshion: BMR Boxed LCA
Nitto DR (17psi)
My reaction - .701
60ft - 2.087
330 - 5.768
mph - 81.08
1/8 et - 8.842
What kind of time do ya'll think ill get in the 1/8th if I lower my 60ft to a 1.8 or 1.9? Also what does the equate to in the 1/4th.
Old Nov 11, 2002 | 07:34 PM
GJE94Z28's Avatar
The site I went to converted your 1/8 ET of 8.842 to a 1/4 ET of 13.84
Here is the calculator site: http://home.indy.rr.com/tlorek/racing_calculators.html
Old Nov 11, 2002 | 10:19 PM
HeavyChevySS's Avatar
I am not an expert on "what times you should run" BUT with having the suspension and tires setup properly;
your car should be cutting consistent 1.8's with an occasional 1.78ish. Good luck man...
Old Nov 11, 2002 | 10:37 PM
Sax1031's Avatar
I say with a 1.8x 60 ft time you should run some 8.60s in the eigth and some 13.50s in the quarter. Now this is all speculation but I would say that is what it would run, on a good run. Good job. Just practice some more.
Old Nov 12, 2002 | 09:49 AM
96 TA's Avatar
Thanks for the replyes, Ill work harder on my 60fts, I do have a problem tho, When I thought I was heating up my tires I was in fact burning up my clutch. My friends said my tires wernt moving at all and all the smoke was from my clutch. Does this mean my clutch is going out or just that I need to back the tires in the water befor a burn out? thanks
Old Nov 12, 2002 | 10:24 AM
1QUIKTA's Avatar
When mine was doing that, it was the clutch. Looks like you will be doing a clutch install this winter. Your 60's should be better with DRs, but the slipping clutch would explain it. I usually pull 2.09-2.10 everytime with not so sticky street tires.
Old Nov 12, 2002 | 10:59 AM
96 TA's Avatar
I Just knew my clutch was going! Damn, If it aint one thing it's another I was hopeing my clutch would be ok. But it's sounds like your right, ill be doing a cluth install this winter! Will it be ok to go the the track one more time? I was also going to put my car on the dyno, is a sliping clutch going to hurt my numbers. If so I wont do the dyno. Thanks
Old Nov 13, 2002 | 08:03 AM
1QUIKTA's Avatar
I would say you'll be fine one more time, but don't hold me to that. The last time on my old clutch, the 2-3 shift was nasty. The engine was reving and I wasn't going any faster. Luckily, the flywheel was fine, just required a light turning. Just don't try and get some super 1.8 60ft with the DRs. Roll out of the lights and then get it going. The dyno question, really couldn't tell ya. I don't have any dyno experience, but I would say it'll hurt ya. If the power can't get to the ground, then it can't register.
Chris
Old Nov 13, 2002 | 08:37 AM
brain's Avatar
Does your clutch slip noticeably when driving around town? If not, then I'd say you'll be ok for a dyno run. Less load all around since the drum weighs less than the car. I ran an 18.1 when my clutch was slipping, and went to the dyno a week later and no problems. BOY was that clutch SHOT!!
Old Nov 13, 2002 | 12:33 PM
96 TA's Avatar
No, not at all. Just when I take the rpms up and dump the clutch.
How about the ram clutch that holds 400hp for $299 Ive been thinking about getting that one becaues all ill have for mods in the near future is just all the bolts on's. I don't plan on going internal for the next couple of years. One more thing, how much do ya'll think a clutch install will cost me? Thanks again to everyone who responded!
Old Nov 13, 2002 | 02:07 PM
brain's Avatar
FREE when you do it yourself. I would expect a shop to charge around $350 - $400 for labor though. Heck, if you PLAN on spending $300 plus labor, you could almost have a McLeod street twin. Keep the extra money for other mods.
Old Nov 13, 2002 | 02:12 PM
96 TA's Avatar
Yeah right! I don't think im good enough to install my own clutch! Can someone tell me step by step how to do it.
Old Nov 13, 2002 | 02:53 PM
1QUIKTA's Avatar
For the install, look up FUNINA91SS for advice. We did mine, as well as, changed the rear fluid and pinion seal. Total time on the project about 6 hours. That was with taking the flywheel to the shop and having it resurfaced and lunch (1.5-2 hours). Make sure you resurface the flywheel-even if it doesn't look like it needs it. BTW, we put in a Star Stage 2. It seems to be doing pretty good for now (550 miles on it). You will need at least 1 other person helping though. Good luck.
Old Nov 14, 2002 | 02:38 PM
97 Z-28's Avatar
Hey Arron, I will help change your clutch out if you want, since I did mine, with Ronnie. It's easier then you think. The hardest part is getting the top bolts off. So if you want to give a wack at it I'll help yah.
Brad
Old Nov 14, 2002 | 09:44 PM
1QUIKTA's Avatar
Brad
Brad, the top bolts are a piece of cake if you go in from the shifter hole inside the car. Just get a long extension (24" maybe not sure how long it was) and put on person inside and the other under the car. The one under the car can position the socket onto the bolt and hold it there. Just an idea, but it worked great.
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
