VE dimensions-could be clue to actual 5th gen dimensions
From GMInsidenews:
All dimensions are the SWB VE.
Overall length
4894 mm = 192.7 inches
Wheelbase
2915 mm = 114.7 inches
Height
1476 mm = 58.1 inches
Width (excluding mirrors)
1899 mm = 74.7 inches
Base engine specs
3.6L V6, peak power 180kW, peak torque 330Nm, four-speed automatic
246.6 hp
Also has a midlevel High output V6
3.6L V6, peak power 195kW, peak torque 340Nm, six-speed manual or optional five-speed automatic with Active Select
267.15 hp
Base V8
Optional 6.0L V8, peak power 270kW, peak torque 530Nm, six-speed automatic
369.9 hp
Overall length
Wheelbase
Height
Base engine specs
246.6 hp
267.15 hp
Base V8
369.9 hp
Re: VE dimensions-could be clue to actual 5th gen dimensions
Too big to be the new Camaro. At least, I hope it won't grow 6 inches in length compared to the concept....192" is within a sliver of 4th Gen size.
the new global RWD platform (zeta) is pretty flexible.. allowing for different cowl to axle distances, different wheelbases, lengths, widths.. the stats for the VE here mean nothing in relation to the Camaro..
With a height of 58", I'm afraid this car will be TOO FRICKING BIG.
Disciple
From: Toronto, Ontario, Canada (20 min. down the road from the "Shwa"!)
Originally Posted by Dan Baldwin
But does it allow for racically shorter cowl HEIGHT?
A radically shorter cowl height? I'm just not sure how to quantify "radically".
Best regardSS,
Elie
Radically = maybe 4" - 6". It'd be nice to have the height under 52", not have the greenhouse too pinched, and not have the fenders too high.
What's it weigh w/ the V8, is that spec out? Just curious, not that it would mean anything for the weight of the Camaro other than perhaps a maximum ceiling...
the only thing on the VE that's going to carry over to Camaro according to those I talk to are the front and rear suspension assemblies and a few ideas used on the VE (such as a front section that bolts in instead of being welded on that contains the radiator support, etc...).
ChrisFrez
Mar 22, 2015 07:00 PM
cmsmith
Mar 16, 2015 02:34 PM
Z284ever
15
Jul 31, 2002 02:07 PM
