Oil pan Gasket
Old Jul 14, 2006 | 01:23 PM
97_TA_WS6's Avatar
Oil pan Gasket
How hard would it be to replace a oil pan gasket on a 98 Firebird?? TIA
Old Jul 14, 2006 | 01:36 PM
Fierotom's Avatar
Re: Oil pan Gasket
not hard!
But the manual says:
Remove the oil level sensor, located in the oil pan, before the oil pan is removed. The sensor may be damaged if the oil pan is removed first.
hope this helps
EDIT: thigtening spec for the oil pan bolt is 14Nm or 125 Lb In and for the Oil Level Indicator Tube Nut
19Nm or 14 Lb Ft
Old Jul 14, 2006 | 01:44 PM
97_TA_WS6's Avatar
Re: Oil pan Gasket
Originally Posted by Fierotom
not hard!
hope this helps
19Nm or 14 Lb Ft
Thanks
So it is pretty straight forward remove put new gasket on then install?? lol I have never worked on the V6 before lol. Is there a write up about it somewhere??
Old Jul 14, 2006 | 01:58 PM
Fierotom's Avatar
Re: Oil pan Gasket
Yes, that's all...... I have the shop manual and there is only one picture with the level sensor.... I think it's very easy.... okay you must buy a new gasket before you starting work
Old Jul 14, 2006 | 02:41 PM
97_TA_WS6's Avatar
Re: Oil pan Gasket
LOL yea that would be important does the level sensor just needs to be unplugged??
Thanks for the help
Old Jul 15, 2006 | 02:52 AM
jonathan_abilene's Avatar
Re: Oil pan Gasket
not hard!
hope this helps
19Nm or 14 Lb Ft
What manual do you have? Helms? My Haynes did not say anything like that!
You have to slid the engine forward to remove the pan i think. I dont know, I took my engine completely out first.
Old Jul 15, 2006 | 04:02 AM
Fierotom's Avatar
Re: Oil pan Gasket
The Haynes is not a godd source for detailed info's about our cars!
I have the original GM shop manuals from 1997 up....
The 1998 F-Body has the 3,8L L36 V6 engine and the manual says nothing to slide the engine.... (I hope this is true)
I think you must unplug the leve sensor for better handling.....
Old Jul 15, 2006 | 02:07 PM
Re: Oil pan Gasket
I'm just saying I think you have to slide the engine forward because the k-member will get in the way of the oil pan.
How the heck can you: "Remove the oil level sensor, located in the oil pan, before the oil pan is removed"???
Old Jul 16, 2006 | 02:31 AM
Fierotom's Avatar
Re: Oil pan Gasket
Hey Jonathan, this is what the GM Manual say's!
okay?
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
