stroker head gaskets
Old Jul 9, 2006 | 06:36 PM
Z284thgen's Avatar
tired of searching here and google with no major results
what i need to know is the cyl bore dia and compression specs on
impala i allready know its .029 compressed but whats the bore diameter
and if there is a different gasket the LT4 head gaskets bore and compr and maybe a GM part number also
i have ran the felpro 1074 on my old setup but im trying to get a lil tighter quench and compression as the heads are 58cc on mine now
Old Jul 13, 2006 | 09:49 AM
Victory Racing's Avatar
Re: stroker head gaskets
I run Cometic's religously on our stuff. They will make anything you want and hold the gasket opening very close to the bore size.
For example their 4.030 bore gasket has a 4.040 gasket opening. Where as a Fel Pro typicall is at 4.125.
Let me know if you are in need and I can get you taken care of. How tight are you looking to run it?
Old Jul 22, 2006 | 07:03 PM
BlackDog's Avatar
What is the advantage of having a tighter fitting gasket?
Old Jul 22, 2006 | 07:05 PM
When I said "tight" I was referring to the quench distance that he wants to run.
Old Jul 23, 2006 | 06:39 AM
BlackDog's Avatar
So, this will increase both quench and compression by using this type of gasket?
Old Jul 23, 2006 | 07:54 AM
Z284thgen's Avatar
i have just went ahead and decided to put my new 1074's on the motor and on the next freshen up i will put my dome pistons in it to get the compression up around the 14:1 mark
right now im at 11.8:1 with the felpros
pending on the gasket bore's i was trying to get it at 12.2:1 or more but i decided to go ahead and assemble it
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
