The joys of replacing window motors.
Old Jul 3, 2006 | 12:01 PM
z28Power's Avatar
Finally got around to replacing my window motors this weekend (they've been non-operational for a year now, lol), and I must say that without the help of this site I would have been a bit frustrated, to say the least. I definitely am not somebody that is overly comfortable drilling holes in my car, even if it is hidden. But I checked out shoebox's guide which helped a ton. My main setback was the numnut at autozone that gave me the wrong window motor. I even asked him before I walked out if this was the bolt-on replacement motor for the riveted version in the car, he said, "yes yes, that's the right motor." I checked it briefly at the store and noticed the size was slightly different but decided that was just because it wasn't OEM. get home, pop off my door panel, drill the holes, pop out the rivets, take out the motor... Good lord. These aren't the same at all. The new one is too small, the wires are coming out the wrong end, it's a rivet on version (thought it was just to slide bolts through the holes, turns out they are WAAAY to deep to fit any size bolt that will fit in that area. So I go online and check autozone's stock, put in the part number he gave me... "Sorry, this part number does not apply to the vehicle you have selected." So I go in, armed with this newfound information and finally get the right part - sure enough looks almost exactly like the one I pulled. He was very apologetic about it, it wasn't really a problem just a minor inconvenience (store is about 1.5 miles away) Anyway, when you have the right motor, the walkthrough does a perfect job of telling you what needs to be done and where to make your holes. I was a tiny bit off on my holes but just expanded them a little bit to compensate, no biggie.
Taking out the speaker is not really a suggestion as much as a necessity. If you are thinking about getting around it without doing this. Save yourself the headache, just take out the speaker. Three screws and you don't even have to unplug the speaker, just set it on the floor int he car. you'll thank yourself when you're trying to get the bolts in the new motor. Which leads me to another thing worth noting. It's a PITA to get the new window motor lined up how you want it WHILE sliding the little pan-head bolts through the holes. I also had to plug in the motor out of the position and move it a little bit up/down to adjust the gears to fit correctly on the teeth, otherwise the holes did not line up correctly and the bolts would not get in all 3 holes, only 1 or possibly two. Have some patience and a bright little drop light that can fit int he door cavity and your life becomes a ton easier, that's for sure.
When I got everything back together though, I was left with 2 working windows and a happy grin at not having to open my door and get out to get a random late night drive through at the local Del Taco or wherever else I would sometimes crave. I'll tell you, people would give you some strange looks when they see a nice car and I'm having to get out of the car to get my food.
I guess I just wanted to share my experience with this and add one or two minor things that I experienced during my swap. Other than that shoebox's guide was dead on as to what I should expect.
Old Jul 3, 2006 | 01:27 PM
WS6NIGHTMARE's Avatar
Re: The joys of replacing window motors.
Ya i know that feeling of having to open the door at the drive through. My daily beater is a BMW, and all my windows work except for the driver one, motor works, just the clip that holds the window itself broke. So the motor will actuate down, but the window goes nowhere. I get those same looks. But hey our cars are probably still more than what they have parked a few feet away.
Old Jul 3, 2006 | 01:38 PM
user 647483's Avatar
My 92 was like that, both motors fried and the AC not working.. UGH
God bless Ttops
Old Jul 3, 2006 | 02:24 PM
Good info, but please post in the correct forum.... window motors don't belong in "LT/LT4 Engine Tech". Moving to "General......"
Old Jul 3, 2006 | 02:55 PM
2001NBMZ28's Avatar
My buddy replaced both of his yesterday, I did one before but he wanted to do it himself, so I just had a drink and offered support. Used shoebox's instructions again with no problems.
Old Jul 3, 2006 | 05:05 PM
2000GTP's Avatar
I just replaced both of them last week. With the help of Shoebox's tutorial, I was done with both in a little over an hour. I was expecting the worst with this job and I thought it was going to be an all day affair. It definitely would have been alot harder without Shoebox's site. The pictures of where to drill the holes to access the rivets was the most help. Thanks again Shoebox.
Old Jul 3, 2006 | 05:46 PM
GrayZ28's Avatar
i just got done replacing the drivers side today and am going to wait till tomorrow to replace the other one. not the hardest job, but IMHO the crappiest. except maybe changing the plugs.
GZ28
Old Jul 3, 2006 | 09:02 PM
Blue89Bird's Avatar
having had to do this on all of my 4th gens, I can do each side in about 25 mins total. I did mine both last weekend, I don't even need to guide to know where to drill anymore.
Old Jul 4, 2006 | 01:12 AM
GrayZ28's Avatar
I also lightened my door in the process. i tried to eyeball it for the holes. i was only off by a little bit so the door isn't that much lighter.
GrayZ28
Old Jul 4, 2006 | 02:11 AM
Compstall's Avatar
I've found it's still easier to have an extra set of hands for the job.
Old Jul 4, 2006 | 02:04 PM
Bow94z's Avatar
So what window motors does everyone reccomend?
Old Jul 4, 2006 | 02:14 PM
2000GTP's Avatar
I just bought a pair of remanufactured motors from a local parts store and they carry a lifetime warranty and ran 53.00 bucks a piece.
Old Jul 4, 2006 | 02:26 PM
JakeRobb's Avatar
Super Moderator
Does anyone make a motor that is faster than the stock ones? Mine both work so far, but when they go out, I'd like to replace them with faster ones.
Old Jul 4, 2006 | 02:50 PM
Bow94z's Avatar
Supposly u run a thicker power wire to make them faster...
How are those ebay motors?? any expericence?
Old Jul 4, 2006 | 03:34 PM
NavyBlueFanatic's Avatar
I just did my drivers side motor today. It was made in Korea so, lets see how well the Koreans make F-body parts.
