knocking when in reverse only
Old Jul 1, 2006 | 05:47 PM
bradsdiscgolfen's Avatar
I have a 96 camaro standered shift 5 speed...whenever i place the car in reverse im hearing a loud knocking...as the drive shaft is making its rotation....had different opinions...please help...where do i start for proper repair???
Old Jul 3, 2006 | 12:24 PM
thezisking's Avatar
Re: knocking when in reverse only
Maybe the bolts that go from your flywheel to your torque converter are loose
Old Jul 3, 2006 | 12:27 PM
84firebird's Avatar
no T/C it's a five speed, but if it's during the shift you coulda wiped reverse, or somethin in the linkage.
but my bet is on the tranny mount, when i tore mine, the driveshaft would bang up on the tranny tunnel during hard acceleration, and when i hit the brakes after being in reverse
other possibilities are
the rear gears jumping, if you knocked a couple of teeth off your ring gear during some wheelhop or rough terrain the rear end will make some knocky kinda noises
the next most likely thing is the u joints, either a blown u joint, seized, or maybe the bolts that hold it in backed off
um, the inner tube of the driveshaft
crappy engine mounts.... axle bearings...
blac94Z
Nov 4, 2015 01:59 PM
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
