P0332, here's the story
Old Jun 18, 2006 | 11:47 PM
RocketCutlass's Avatar
on my 02 Z, im gettin the low input code on #2 knock sensor, so i took the diablo tuner out and took her for a ride after deleting the code. cruisong around everything is normal, at WOT im gettin 3.96 degrees of retard. when i first put the diablo tune on it, i would get a little retard but after a second it would go back up to 0 retard under WOT, now it stays at 3.96 degrees and i can hear some pinging. Bad sensor? if so how do you replace? and i am using premium and regularly run a fuel system cleaner through her.
Old Jun 19, 2006 | 01:50 PM
2001NBMZ28's Avatar
Re: P0332, here's the story
Dunno...maybe it's doing it's job by sensing the pinging? Check the diagnostics at www.gearchatter.com You need to remove the intake to get to the sensor, the intake swap article at www.ls1howto.com shows you how if you have to ge that route. Sorry no definitive answer, TTT for ya.
Jeff1904
Jun 5, 2016 05:00 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
93 RedBird
Nov 15, 2015 08:24 AM
NewsBot
Sep 16, 2015 10:30 AM
NewsBot
Sep 14, 2015 08:50 AM
