Supercharging 91 Z28?
Old Jun 14, 2006 | 10:26 AM
ILOVEGINA's Avatar
i am looking into supercharging my 91 z28 tpi. is it anygood? would it give me alot of ponies or is it just a dud? does it work well with the tpi setup? please let me know because i don't want to drop 3 grand on somethin that wont give me substancial power and torque increases. thanks
Old Jun 14, 2006 | 10:54 AM
Rice Killer87's Avatar
Re: Supercharging 91 Z28?
Force feeding the TPI is the best way to get it to turn some RPM's.
Ive never had a S/C TPI but ive heard it runs well.
Old Jun 14, 2006 | 11:25 AM
Tex95Z's Avatar
LoL @ your screen name
Supercharging would be a great idea
Old Jun 14, 2006 | 06:35 PM
mako350Z28's Avatar
TPI setups take very well to boost, just don't overdo it. You don't want to spend 3 grand on a supercharger and then have to shell out for a new engine. At most the engine will safely handle about 8 lbs of boost. But even then be on the lookout for detonation. That will ruin your little project very quickly.
But from what I have seen 8 lbs will give you roughly about another 100 ft-lbs and another 200 horses.
Old Jun 14, 2006 | 10:08 PM
ILOVEGINA's Avatar
Thats the name of the car
Old Jun 14, 2006 | 10:10 PM
ILOVEGINA's Avatar
so is it safe to run 8lbs of boost in a stock tpi setup? i only have a cam in it.
Old Jun 14, 2006 | 11:57 PM
89Vert's Avatar
I wouldn't run 8psi on a TPI
iron heads for 1 too much effective compression ration,
I run 8psi on a 95 LT1 camaro and it killed the stock bottom end, car only had 80,000km and ran boost about 10,000km
5 psi would be more reasonable
Old Jun 15, 2006 | 12:31 AM
BrandonKeith's Avatar
That's because the Powdered Metal Rods in a Stock LT-1 aren't really all that great. The first 2 years of the LT-1 had Forged Rods and then GM went to the Powdered Metal Rods for 95 because they were cheaper to make. I had one in my N/A stock motor snap in 2 places while cruise'n at 75mph on the highway. Also my motor had just turned over to 58k miles. There was a slight lean issue in that cylinder.
So, his rods should be up to the job and hold out just fine.
Old Jun 15, 2006 | 09:08 AM
89Vert's Avatar
killed the bottom end due to excessive bearing clearance,
causing low oil pressure
Old Jun 15, 2006 | 02:10 PM
mako350Z28's Avatar
L98's have less compression than an LT1. And you can do it but you have to be careful of detonation b/c of the increased heat from the iron heads. Most people run 6 lbs.
Old Jun 15, 2006 | 09:41 PM
ILOVEGINA's Avatar
thank you! you guys are awsome! so for heads then, any ideas??
Old Jun 15, 2006 | 10:11 PM
89Vert's Avatar
Aluminum would be best, can handle higher compression with out detonation
Old Jun 16, 2006 | 12:54 AM
blkzdrgn's Avatar
ITS FUNNY THAT I CAME ACROSS THIS SUBJECT... WELL I CURRENTLY HAVE A 91 Z28 WITH A PROCHAGER SUPERCHAGER ON AND I WILL TELL YOU ALL THE IN'S AND OUTS IF YOU LIKE,
IAM A LITTLE TO NEW THIS POSTING REPLIES AND STUFF AND PLUS IAM NOT ALWAYS ONLINE SO IF YOU LIKE YOU CAN REACH ME ON MY REGULAR EMAIL IF I DON'T IT HERE IN TIME
BLKZDRGN@HOTMAIL.COM
Old Jun 18, 2006 | 09:36 PM
ILOVEGINA's Avatar
now my next question is what alum heads should i get?
Old Jun 19, 2006 | 10:28 AM
GM Fast Burn.
alex5366
Feb 17, 2015 09:07 AM
cyteone
Feb 7, 2015 06:04 PM
CARiD
Jan 27, 2015 06:27 AM
ChrisFrez
Aug 12, 2002 11:50 AM
