Comp Cams "Nostalgia Plus" N+L79H OR N+30-30H cams?
Old Jun 12, 2006 | 03:33 AM
Ron78Z&01SS's Avatar
I've been a little unsure whether to go for an L79 cam or something a little hotter in my 327.
I came across this earlier today and it definately caught my eye. Supposedly they claim to have the sound of the original cam but improved power of modern cam design.
They claim:
"The famous factory camshafts meet the future.
These famous factory camshafts of the past are combined with the latest advanced camshaft technology to give you the sound and excitement of the musclecar era. These Nostalgia Plus cams are specifically designed to capture the essence of the original '60s musclecar, with additional power you can feel in the seat of your pants. The new technology creates awesome response, to give new life to any hot rod
They have Hydraulic "Nostalgia" versions of the 327/300hp, L79 & 30-30 cams along with a solid 30-30 variant.
From the Comp Cams site: http://www.compcams.com/information/...yID=1143295200
The numbers of the ones I would consider are:
N+L79H :
Duration @ .050 : 229 int./236 exh.
Valve Lift : 0.468 int./0.462 exh.
Lobe Separation : 112
Claimed RPM range 1,800-6,200rpm
For comparison, stock L79 specs: 222 int. & exh. @ .050 / .447 Int. & Exh. lift with 114 Sep. 1800-5800rpm range
N+30-30H :
Duration @ .050 : 239 int./246 exh.
Valve Lift : 0.483 int./0.477 exh. lift
Claimed RPM range 2,300-6,500rpm
Even though I listed it, I'm not too much on the N+30-30H being that it would probably be a dog down low with my 3.36 gears.
The N+L79H though looks to be just the ticket for me. I should still have the coolness of having an L79 sound (they claim), but with more duration & lift for a lot more power. I'm assuming from the tighter lobe seperation and identical lower rpm range that I won't take a hit in low end driveability/torque in relation to a "real" L79 cam.
I think I've decided on my cam . Any thoughts or suggestions? :bigears
If it matters my 66 Vette has a 327 muncie with 3.36 rear gears. I'll probably be using Trick Flow aluminum heads which will give me 10.3-10.4:1compression. If I decide to go with Dart Iron Eagles instead (not likely though), I'll be running approx 9.35:1.
Old Jun 12, 2006 | 11:23 AM
angel71rs's Avatar
Re: Comp Cams "Nostalgia Plus" N+L79H OR N+30-30H cams?
Even the smaller cam is a little big for 3.36 gears, especially with a 327, IMO. I ran a 230 cam in a car w/350 & Muncie 2.54 1st/3.36s, it ran ok, but was better with a mid 220 cam.
Your car wouldn't be a hound, but you'd have to wait a bit till it got up on the cam. I'm not buying the claimed 1,800 rpm for the bottom of the band. A hyd cam w/230* isn't going to come on strong till it's crowding 4k, new tech or not. Would be killer w/4.11s.
I think something in the low/mid 220s would be a lot more fun to drive around town with your combination. The cam I run in my 400 would be my 1st choice: http://store.summitracing.com/partde...5&autoview=sku
2nd choice would be the XE268 from Comp, makes great power, peaks ~ 6k in a 350: http://store.summitracing.com/partde...5&autoview=sku
Use 1.6 rockers, and since you're considering flat tappet cams, look into the zinc issue if you want to avoid rounded lobes with your new cam. Whatever you do, do not run the severely outdated L79 cam. It still has a rep, so some people use it. But I saw a heads up comparison vs. a HE 218* Comp cam in a mag. 218* cam made more low end, mid range, and about 25 hp more upstairs.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
Amshnock
14
Jan 18, 2015 11:47 AM
