Help! removing IAC
Old Jun 1, 2006 | 10:52 PM
RosadOC-Z's Avatar
Help! removing IAC
I have free time so I plan on taking off the IAC and cleaning it but after looking at it, I dont see how i can fit a big enough wrench in there. Do you guys have any suggestions on how to do it. It seems like a bracket holding the alternator could be removed because it is in the way. I also already removed the intake assembly connecting to the throttle body. What do you guys usually do.
By the way this is a 5.7 TPI 350
Old Jun 1, 2006 | 11:36 PM
Black305RS's Avatar
Re: Help! removing IAC
you could always remove the throttlebody and take it off that was but you should be able to get a wrench in there just work with it.
Old Jun 2, 2006 | 12:14 AM
89Vert's Avatar
what year? got to be an 87 is alt is in the way
Old Jun 2, 2006 | 06:35 AM
RosadOC-Z's Avatar
yeah its an 87
Old Jun 2, 2006 | 02:33 PM
elementaltoad's Avatar
i fit a box end wrench around it and did it little by little, it takes a while to unscrew it but it was easier because i did not want to take the TB gasket off and mess with all of that.
Old Jun 3, 2006 | 11:33 PM
RosadOC-Z's Avatar
using channel locks and coming at it from the side worked for me. thanks for all the suggestions.
marlar98
Sep 19, 2015 07:53 AM
tdigger9899
Sep 7, 2015 10:56 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
reww86
Aug 29, 2015 06:04 PM
4586
Jul 31, 2015 06:03 PM
