1991 air conditioner recharge/upgrade
Old May 31, 2006 | 03:28 PM
skycabo's Avatar
Hi folks
I am new to this site. I have a 1991 firebird. I am told that it needs a recharge and also an upgrade to the new refrigerant or find some of the old.
Any site, forum or advice? Have any of you 3rd generation owners already done this procedure? Thanks in advance.
Phill in Illinois
Old May 31, 2006 | 04:38 PM
krazzycowgirl's Avatar
Re: 1991 air conditioner recharge/upgrade
Originally Posted by skycabo
Hi folks
Phill in Illinois
Go to your closest Jiffy Lube or a place that does A/C work they will do it for you
Also if you are looking for 3rd gen Advice got to www.Thirdgen.org
Old May 31, 2006 | 04:59 PM
Black305RS's Avatar
make sure they test your system before its recharged chances are it has a leak in the condenser as was the case both my 91s and my 89. ac repair work can be quite pricey just so you know.
Old May 31, 2006 | 05:08 PM
1991l98g92's Avatar
2 years ago mine wasn't blowing as cold as it should. Since I have an A/C certification, I purchased 3 cans of R12 from Kragens, $15 each plus 2 cans of oil charge. Put 1 can of oil and 1 can of R12 and it's back to good as new. The compressor is leaking a little oil and slinging it on the hood insulation. Not too bad after 15 years. I would recomend having it leak tested, and if not too bad, recharge with R12 if possible. I still have the other 2 cans waiting if needed. If a big leak jis detected, that would be the time to retrofit if it's what you want to do. Could be costly.
Old May 31, 2006 | 05:47 PM
91Z-28's Avatar
I need some R12 so I can recharge my AC, but it seems I can't buy it without an EPA cert. Are there any other options? I don't want to use r134a because I've heard about how poorly it performs in an R12 system.
Old May 31, 2006 | 05:48 PM
Black305RS's Avatar
i retrofitted to r134 in my 91 rs and it worked fine it only lasted a day due to a hole in the condenser but it got cold.
Old May 31, 2006 | 07:00 PM
skycabo's Avatar
Thanks for all the replies.
The thirdgen.org site seems to have all the info I'll need.
I'll let you know how it goes.
I'll also ck back for any new replies.
skycabo's Avatar
Old May 31, 2006 | 07:28 PM
91Z-28's Avatar
That is what I heard about converting to r134a, that it will **** up the r12 components pretty fast. I've also heard that r12 is MUCH colder in the r12 systems.
Dec 1, 2016 05:37 PM
Latronaxe
May 14, 2015 01:23 PM
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
