Need Part number for 3150 U Joint
Old May 30, 2006 | 06:55 PM
5.7LT1Formula's Avatar
Just bought a moser 12 bolt and getting my stock drive shaft shortened and i think i'm going to need a bigger u joint in the rear of the shaft. can anyone tell me the part number and dimensions of the 3150 u Joint? if you can sketch up a diagram w/ dimensions would be great!
(i know i shouldn't use my stock shaft but i only have 400 or so to the ground)
Old May 31, 2006 | 07:35 PM
smallblock458's Avatar
Re: Need Part number for 3150 U Joint
The part # of a 3150 u joint should be 3150. The drive shaft shop you are going to use will know what to do. I would find out what they would charge for a new shaft. I got a price of $300 with one 1350 and one conversion joint in an aluminum 3.5" shaft new.
Old Jun 1, 2006 | 04:42 PM
n2ceptor's Avatar
I believe Carquest goes by Part # 3-3150.... If you have one close by give them a call.... They should be able to look up the specs.....
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
ElkyRacer
Sep 19, 2002 02:33 PM
