What is this diff part?
Old May 29, 2006 | 03:37 PM
Silver's Avatar
The small bolt in the middle that goes through the little tab in the center of this diff.
It was loose... just wondering how tight it needs to be. A small wrench is the only thing that'll get between it and the clamps - it's an 8mm if I remember correctly.
http://bellsouthpwp.net/p/o/powe5959/imag0026.jpg
Old May 29, 2006 | 04:03 PM
rngilliland's Avatar
Re: What is this diff part?
I just tighten it good and snug with a small box end wrench. I think the part in the middle that the bolt goes through is called a paddle. It keeps the axles from moving inward so the c clips won't fall off. It may have other functions too. I'm not sure. You probably already know but that is a Torsen differential.
Old May 29, 2006 | 05:14 PM
Silver's Avatar
yes a torsen. these things don't have clutches do they?
i figured it had something to do with the clips b/c it was the only think I could see that actually came loose.
Old May 30, 2006 | 09:00 AM
No clutchs. It uses gears.
novaiiman
May 15, 2016 11:36 AM
ddr698
Jan 9, 2015 10:05 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
