East South Central Alabama, Kentucky, Mississippi, and Tennessee
Anybody have an idea on this no start?
Old May 29, 2006 | 12:41 PM
stingercamaro's Avatar
Hey guys, I've reached the end of my testing and I have absolutely no idea what is wrong with my car. Long story short, the ICM, coil, opti, opti harness, and PCM have been replaced but I still have a no fuel, no fire problem.
The car cranks just fine, but the fuel pump doesn't kick on (pump is good) and there is no fire out of the coil.
Yesterday, I pulled the black (i,think) connector off the PCM and tested the hi and low res pulses for voltage and didn't get anything.
Any ideas?
Thanks
Matt
Old Jun 4, 2006 | 07:13 PM
ss rally red's Avatar
Re: Anybody have an idea on this no start?
Make sure there is no VAT's (security problem) fairly common on F bods.
Old Jun 5, 2006 | 10:13 PM
I think I found the problem, no ignition feed to the PCM
Old Jun 12, 2006 | 02:11 PM
mkent's Avatar
How did you end up fixing it? I think I may have the same problem.
Old Jun 21, 2006 | 12:42 AM
Sorry it took so long, haven't visited this section in a while. All I did was run a thicker gauge wire from the "ign" fuse under the hood to a butt connector which contained all the wires that supply ignition feed.
BPS
9
Mar 5, 2015 10:51 PM
armedtrigger
Feb 24, 2015 08:30 PM
maybe2fast
Feb 5, 2015 05:14 AM
HCz28
Jan 11, 2015 11:21 AM
