Vendors for complete bolt-up 12 bolt rear ends.
Old May 29, 2006 | 09:36 AM
wrd1972's Avatar
As the title says, where can I get completely ready to bolt up rear ends? Do they also sell the drive shaft?
Old May 29, 2006 | 11:02 AM
Re: Vendors for complete bolt-up 12 bolt rear ends.
If you buy a Strange 12-bolt, it will come fully assembled, lubed and run-in at the factory. Direct bolt in and works with the stock DS length. You may have to get a cross-over U-joint, since it doesn't make any sense to use less than a 1350 yoke on the Strange.
If you prefer a bit of "some assembly required", there is also the Moser 12-bolt. They sometimes require a shorter DS length, require different sway-bar mounts, and have a frequent problem with the bolts on the torque arm.
For a source, check out the companies listed in the "Supporting Vendor" link at the top of every page of the forum.
https://www.camaroz28.com/misc/vendorindex/
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
redleader
Jan 22, 2015 12:05 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
