Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
LS1 And LS2 Meziere Electric Water Pumps
Old May 23, 2006 | 02:58 PM
tbyrne's Avatar
We are clearing out of current stock of black Meziere electric water pumps for the LS1 motor.
The in stock pumps will not fit the LS2. Meziere has just completed a batch of pumps that will now work on both motors. They put a relief in back of the pump body and milled a pocket to clear the LS2 throttlebody. The pump now says "LS" insteaad of "LS1" but the neck still says "LS1"
These pumps have been tested at the track, on the dyno and most importantly, during street driving. They have allowed engines to run cooler at low speeds and gain high end horsepower. In addition to the released power, you get to keep all of your factory accessories. Taking quality to the extreme, the WP319 features a dual bearing belt idler, billet parts throughout, and a “weather-tite” electrical connection. The pump is backed by a two-year warranty. If you own GM’s hottest cars, you need Meziere’s newest, coolest pump.
Features:
Purpose built for street use – 3000+ hour life expectancy.
Fully polished or anodized in your choice of 4 colors (Black,Blue,Red,Natural).
Chrome upgrade available.
55 GPM free flowing rating.
All stainless steel hardware included.
Heater and bypass provisions.
Light weight. Complete standard LS-1 unit weighs only 14.9 pounds!
Stainless steel large diameter main shaft with high performance ceramic seal.
Inlet fitting supplied to match stock configuration.
Easy install - truly a "bolt-on" pump.
Full two year warranty - the best in the business!
Finishing The System:
This pump is supplied complete with gaskets and hardware, complete and ready to bolt on. The only additional item you will need is a standard Chevrolet thermostat if you desire to use one. It will install behind the exit fitting located above the idler pulley.
Amperage draw:
Under normal use the pump will draw 11-12 amps.
Overall Height Dimension:
The standard pump is 7.88" long from the mounting surface to the tip of the pump.
Pump Weight:
This application weighs 14.9 lbs.
WP319S Meziere LS1electric water pump (black)
Our sale price is $519.99. This includes a free thermostat and free ground shipping in the 48 states. Orders can be placed online or by calling 1-877-482-9763.
We will honor this price if anyone wants to pre-order one of the new LS2 pumps. They should be arriving here soon.This offer will be ending on Friday, June 2nd.
Have a good day!
Old May 24, 2006 | 11:18 AM
tbyrne's Avatar
Re: LS1 And LS2 Meziere Electric Water Pumps
We've found that our recent shipment contained some of the new pumps so we now have the LS2 pumps in stock! Those say LS1 on the front but they will fit everything now. This shows the different between the two -
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
