Rear window defrost
Old May 20, 2006 | 01:04 PM
shock6906's Avatar
Rear window defrost
Not too long ago, my rear window defroster stopped working on my 97 Z-28. I checked the fuse and it's fine, I located it down to the switch itself. I pulled the panel apart to find out that there's a circuit card inside and maybe that is the problem. Do I need to replace the whole panel, A/C controls and all, or can I just replace the card inside?
Old May 20, 2006 | 06:43 PM
fredmr39's Avatar
Re: Rear window defrost
Isn't there a breaker as well? or is that what you meant
Old May 20, 2006 | 09:39 PM
shock6906's Avatar
breaker/fuse, yeah, that's what I meant...but it works because I swapped it with the one under it and there was no change. Also, it's the same breaker that the power seat is ran through, and the seat works fine.
Old May 20, 2006 | 10:55 PM
IROC-T's Avatar
Did you check for breaks in the window grid? See if you are getting power at the window.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
guruerror
Mar 4, 2015 06:25 PM
dale3in98
Feb 14, 2015 12:18 PM
Fatdog2
Jan 24, 2015 12:08 AM
kizz
Jul 6, 2002 11:03 AM
