Camaro's in the Shop more often?
Old May 18, 2006 | 02:34 PM
schwing's Avatar
I am looking for a Z28 or a Trans Am/Formula and have been hearing that camaros are in the shop more often...just wanted everyones personal opinion.
Old May 18, 2006 | 02:49 PM
2001NBMZ28's Avatar
Re: Camaro's in the Shop more often?
Bought mine new in April '01 - only problem has been a window motor.
Old May 18, 2006 | 02:53 PM
schwing's Avatar
I was just wondering because it seems that I can find Z28's for mcuh less than than same year Trans Am. Just didn't know if it was due to this or possibly just higher avalibility of Z28's
Old May 18, 2006 | 02:58 PM
BradcTA's Avatar
Z28=Formula
SS= Trans Am (WS6)
Trans Am is more of a visual package (Like the V8 RS 98-02)
Old May 18, 2006 | 03:07 PM
Craddock's Avatar
I'm pretty sure there wasn't ever an RS that came stock with a V8 in fourth gen cars.
Old May 18, 2006 | 03:29 PM
MyShibbyZ28's Avatar
My thoughts too.
Z28 = Trans Am
SS = WS6
Old May 18, 2006 | 03:31 PM
BradcTA's Avatar
Well, I almost bought a 98 Z28 m6 with the "RS" package. It has ground effects. That why I was thinking Rs with a V8 but I should have said Z28 with the RS package
Old May 18, 2006 | 03:35 PM
'99 SS's Avatar
Anyone who's telling you Camaro's are in the shop more often....
I've had the SS for 7 years now, w/o any mechanical issue.
Old May 18, 2006 | 03:42 PM
thesoundandthefury's Avatar
Outside of appearance, the two cars are identical. Same drivetrains, same frame, same suspension, everything. There is nothing to indicate that a Camaro is more likely to break down than a Trans Am. Either car is equally susceptible to mechanical failure. I think you may be hearing someone's biased and subjective (what isn't) viewpoint due to them probably just knowing more people with Camaros than with T/A's.
Get the car you want.
Old May 18, 2006 | 03:47 PM
Shon Herron's Avatar
If you leave the things alone and drive it like the "typical american" as which these cars were built for you will not have many issues. Start pushing them and modifing them then you open a can of worms.
STOCK is the only way to go....
Old May 18, 2006 | 05:32 PM
95GRNZ's Avatar
Exclamation Re: Camaro's in the Shop more often?
Me thinks you shouldn't listen to that kind of people at all.
Old May 18, 2006 | 11:47 PM
schwing's Avatar
I agree with you. I do like the way Trans Am's body styling more I am not sure which I would prefer to purchase but thank you all for your input.
Old May 18, 2006 | 11:57 PM
bmotwani's Avatar
yes camaros of those who don't know what they're doing end up in shop often. Know yr car & it's history and the don'ts of maintenance & u'll be fine for many years.
Old May 19, 2006 | 03:32 PM
1quickTA's Avatar
Well it makes since - weren't a lot more camaro's sold than trans am's??? But percentage wise no, they should be the same because they are the same car mechanically. You are just as likely to find yourself in the shop with either car. Just get the one you like most!
Old May 19, 2006 | 04:11 PM
Kris93/95Z28's Avatar
The reason here is simple. The T/As cost more from the factory, and the average T/A usually has more options than the average Z28. The fact that they cost more new, and would likely have more options will easily explain the difference in price.
As stated before, the cars are the same under the shell, they are both suceptable to the same issues.
AlaskaZ28
Jan 1, 2015 12:30 PM
Hurin
Dec 13, 2014 07:38 PM
mspennyhughes
Nov 28, 2014 03:22 PM
draven666
Nov 26, 2014 07:16 PM
draven666
Nov 26, 2014 07:10 PM
