Cat question
Old May 17, 2006 | 09:27 PM
bcanz's Avatar
Cat question
I have a completely stock 94 Z. I wanted to remove the catalytic convertor and replace it with a stainless pipe piece what diameter should this piece be?? Thank.s
Old May 17, 2006 | 09:42 PM
skibbez93z's Avatar
Re: Cat question
well what diameter of exhaust do u have on the car? i am assuming if u r running a 3 inch pipe u want 3 inch pipe. but i am assuming u arent, because if u were u would know which size? i dont know.... just go with what size of pipe is on there. it depends
Old May 17, 2006 | 09:47 PM
bcanz's Avatar
Re: Cat question
I am running the stock 3". Wouldnt I want something a bit smaller to fit inside the 3 inch pipe?? or stay 3 inch.
Old May 18, 2006 | 01:20 AM
fredmr39's Avatar
Re: Cat question
depends...if you are welding, 3 inch is preferred - it you want to do this yourself and be able to swap it out, you'll want to find a off road pipe that's of slip-fit design.
How do you plan on securing the pipe?
Old May 18, 2006 | 11:03 AM
bcanz's Avatar
Re: Cat question
I was just going to clamp it on.
alex5366
Feb 17, 2015 09:07 AM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Dec 1, 2014 08:08 AM
