Best sway bars and sizes
Old May 11, 2006 | 07:59 PM
mook99TA's Avatar
I am looking at the spohn front and rear sway bars. The car is for a dd and occaisional track time both strip and autox. I know I want solid but not really sure what size's and what brand are the best.
Old May 11, 2006 | 10:41 PM
teke184's Avatar
Re: Best sway bars and sizes
hard to go wrong with the 32/21mm bars from BMR
it's a good all around setup...made AMAZING improvements on my cars handling...on both my 96 and now my 99
Old May 12, 2006 | 12:49 AM
Bud M's Avatar
Not sure why you want solid bars, I'd get Strano's 35/22 bars, 32 is a bit small on the front and Spohn's 32/22 combo will be tailhappy. Strano's will be lighter too. I've had the BMR bars and they are not bad but the Strano front bar is better IMO.
Old May 12, 2006 | 05:49 AM
5.0THIS's Avatar
I guess he wants heavier parts that arent hardly any stiffer
Old May 12, 2006 | 10:48 AM
NOSCaMaRo's Avatar
Call Sam Strano, he will be happy to explain what is best and you need, esp. since it seems you are doing some AutoX
Old May 12, 2006 | 02:37 PM
mook99TA's Avatar
what do you mean by tail happy?
Old May 12, 2006 | 07:16 PM
stereomandan's Avatar
If hollow, go with the Strano 35mm front and 22mm rear, if solid then go with the 35mm Suspension Techniques bar and 1LE 21mm rear bar.
I have the two solid bars mentioned and it made an incredible difference in handling. By far the best handling mod I've done.
Dan
Old May 12, 2006 | 09:15 PM
Bud M's Avatar
A stiffer rear roll bar will give the inside rear tire less grip, making the rear slide more easily in turns. The 32/22 combo will make the anti roll balance stiffer at the rear. The optimum setup seems to be 35/21 solid or 22 hollow, assuming wider 17" wheels. With stock 16" wheels, a 19 mm rear bar might be better.
Old May 13, 2006 | 09:00 AM
mook99TA's Avatar
thanks
96SilverRam
Nov 20, 2016 11:19 AM
96SilverRam
May 28, 2015 02:09 AM
96SilverRam
May 5, 2015 09:56 PM
BLK1997Z28
May 1, 2015 12:23 PM
8T8IROC
Mar 26, 2015 09:02 PM
