Strange wear on new pad install....
Old May 10, 2006 | 01:04 PM
Z94SLEEPER's Avatar
Question Strange wear on new pad install....
I replaced the pads on the front of my Z about 2 weeks ago and ever since, it looks as if only half of the pads are actually using the disks (slight rust look on the disks).
When I took off the old pads I went ahead and took out the bolts/pins for the calipers, cleaned them and re-greased them with the proper grease then placed everything back on with the proper torque specs per the Haynes manual. I also had the brakes bled before the new pads and went on. The car seems to brake well enough although I haven't gotten on it really hard because of the way the disks look...
Any ideas of why the pads are not using all the disk before I pull them off again?
Old May 10, 2006 | 08:18 PM
RE AND CHERYL's Avatar
Re: Strange wear on new pad install....
My Hawk HPS pads did that when I installed them. Don't know what caused it but after a week or two all was well.
Re'
Nayr
Mar 3, 2023 08:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
IndyZman
Oct 22, 2015 02:17 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
tdigger9899
Sep 7, 2015 10:56 AM
