Lifters
Old May 10, 2006 | 10:13 AM
k9ulan's Avatar
Lifters
I put a crate 350 in my 67, in less than 50 miles it startred ticking. had a lifter collapsed on the no.2 exhust valv..installed a new lifter, still ticking, i guess its not pumping up, no oil out of the push rod., I didnt soak my lifters long..(i know i should have) before i installed the new one, could this somehow not pump up if its not primed, i thought, "and maybe i thought wrong" it would pump itself up after running a bit., only other thing i can think of is a clogged lifter oil gallery, if so anyone ever run into this problem?
im sure its not the headers or fuel pump,
Old May 10, 2006 | 12:42 PM
markinkc69z's Avatar
Re: Lifters
If its a flat tappet the lobe could be going flat.
Old May 10, 2006 | 02:34 PM
k9ulan's Avatar
Re: Lifters
i wont rule that out, but itsa brand new cam and lifters, in a fresh crate engine, im saving that option for last
Old May 10, 2006 | 06:08 PM
Re: Lifters
That's why I suggested it. The cam is most likely to go flat right off the bat.
Old May 10, 2006 | 07:44 PM
84firebird's Avatar
Re: Lifters
he is right, cams go flat fast if they go flat at all
Old May 10, 2006 | 08:32 PM
Dave89IROC's Avatar
Re: Lifters
yeah, either right away or high mileage(all the flat cams I have seen were under 1000 miles, or over 125K miles)
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
