Will the Camaro's next M6 be based on an automatic?
Old May 10, 2006 | 09:12 AM
Z284ever's Avatar
http://media.gm.com/division/2004_pr...ary_manual.pdf
Old May 10, 2006 | 09:18 AM
Chrome383Z's Avatar
Re: Will the Camaro's next M6 be based on an automatic?
I really don't have a problem with it. If it allows GM to save and spread development costs; and can hold up - I think it'd be a winner.
Just think maybe somebody could do a Manual/Automatic swap and utilize the same Transmission case...
JakeRobb's Avatar
Super Moderator
That looks awesome in theory. Can't wait to see it in execution. Does it have a clutch pedal?
Old May 10, 2006 | 09:35 AM
Z28x's Avatar
Sounds interesting. Whats the deal with the "Park" gear? maybe it is so a remote car starter can be used w/ a manual.
I only wish the R & P were next to 5 & 6
Old May 10, 2006 | 09:43 AM
JakeRobb's Avatar
Super Moderator
I figure it works the same way Park works in an automatic, so that you could park on a hill and not need the E-brake. (Personally, I'd use it on hills anyway).
It might also engage other previously automatic-only features, for instance the feature (if you want to call it that) that prevents you from removing the key unless the car is in Park.
Old May 10, 2006 | 09:54 AM
NikiVee's Avatar
Hmmm. I wonder if i can retrofit my 72 Lemans with that? That would be cool.
Old May 10, 2006 | 10:15 AM
Diognes56's Avatar
Interesting .
David
Old May 10, 2006 | 10:44 AM
IREngineer's Avatar
If I had to guess, I would say the park gear allows you to use a keyless start without a clutch. It also reduces a ton of complexity. For me, it means I can get a manual that my wife can drive, with remote start to boot! I would wait until the 2nd or 3rd year of production on this tech for sure
Old May 10, 2006 | 10:46 AM
Z284ever's Avatar
So is this a good thing or a bad thing for the manual trans crowd?
Old May 10, 2006 | 10:51 AM
Chrome383Z's Avatar
So would this operate like a Manual that we're all familiar with or do you think it is more like a manual valvebody Automatic. Of course the Dry Input Clutch suggests... Hell I dunno what it suggests...
It's nice to see them thinking outside the box I guess...
Old May 10, 2006 | 11:01 AM
JakeRobb's Avatar
Super Moderator
The most important question, to me, is if the system uses a torque converter or a clutch, and in the case of a clutch, is it automatic or is there a pedal?
I'm guessing it's a torque converter, and that this is really just an automatic transmission with "autostick", but without the "auto" mode.
I want a clutch, with a pedal.
Old May 10, 2006 | 11:05 AM
Z28x's Avatar
Clutch pedal is my guess.
Park probably puts the engine in neutral but locks the trans so that the wheels can't move.
Old May 10, 2006 | 11:11 AM
IREngineer's Avatar
I really don't know. This is new to me too. I would expect this to eliminate the clutch, since there really isn't too much of a gain otherwise. I also hope that this is true clutchless manual. If it's an "autostick" I would be disappointed.
Old May 10, 2006 | 11:16 AM
IREngineer's Avatar
Let's also look at the fact that GM has actually released something about this. Based on past experience, that means it is potentially about 5-7 years from seeing production. Can you imagine?
Old May 10, 2006 | 11:22 AM
stars1010's Avatar
As long as it feels like an M6 (I need a clutch pedal) and holds up to large amounts of power I dont care
