MOOG balljoint install?
Old May 9, 2006 | 12:50 AM
fireman's Avatar
This new MOOG lower balljoint does not want go in. Can someone tell me how to do this?
thanks
Old May 9, 2006 | 09:16 AM
firebird84's Avatar
Re: MOOG balljoint install?
well you pounded the old one old right with a jack under the control arm. Well to put it back in raise the car up remove the jack stand and put it under the ball joint. Then just lower the car untill the balljoint pushes in. OH yeah dont forget the boot may need to go on after you install the balljoint. that is the easiest wayif you ask me.
Old May 9, 2006 | 09:45 PM
fireman's Avatar
Well, I tried jacking the balljoint up in there and after the control arm maxed out, the whole car just started going up. I have heard that the MOOG balljoints are more difficult to install than other balljoints.
Old May 10, 2006 | 12:50 PM
My Iroc Z28's Avatar
go to autozone rent a ball joint press and do it the correct way.. if you do it incorrectly you may run into problems.
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Fatdog2
Apr 10, 2015 12:07 AM
8T8IROC
Mar 26, 2015 09:02 PM
ModdedNerd
Dec 25, 2014 05:51 PM
