steering shaft colapsed
Old May 5, 2006 | 10:02 PM
sc1twntrbo's Avatar
i installed a ragjoint eliminator on my steering shaft and when i went back to install it i noticed that i colapsed the shaft somehow. and i was wondering if i could just pull it out and reuse it or if i need to replace the shaft. the reason i ask is because i remember reading that if your car was in an acident and the shaft colapsed it should be replaced. well mine is colapsed but was never in an accident
Old May 7, 2006 | 03:35 PM
OBE1 95Z28's Avatar
Re: steering shaft colapsed
Describe "collapsed". If you mean that the one shaft is able to slide in and out of the other shaft, this is normal and is used to adjust the U-joint position so as to clear the exhaust.
Ericksd
Jan 20, 2016 06:07 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
rideordie
Sep 7, 2015 08:22 AM
