265-35-18 tires?
Old Apr 30, 2006 | 05:12 PM
baddboy1705's Avatar
265-35-18 tires?
(265-35-18)will these fit on my 96 Z28 without me having to grind anything?Or are they way to wide...? thanks
Old Apr 30, 2006 | 08:35 PM
Re: 265-35-18 tires?
or not.....
Old Apr 30, 2006 | 11:16 PM
You aren't getting answers because you posted on the wrong forum.... I'll move it to "Wheels and Tires" for you.
A 265/35-18 is about 1/2" smaller than stock tire diameter, so its not a good choice. That opens up the gap between the tire and the fender slightly, provides a narrower sidewall for less rim protection from potholes and a harsher ride, and screws up your speedo unless you correct in the PCM.
You should be looking at a 275/35 or a 285/35 if your wheels are 9.0-9.5" wide. Whether they will rub depends on the width and offset of ther wheels they are on. If you locate the wheels correctly in the wheel wells, 285's should not be a problem.... the WS6 and SS models came with 275's from the factory and they don't rub. Many of us are running 315's in the back with minor hammering.
Old May 1, 2006 | 05:33 PM
oops...my bad...thanks
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
