bad vibration in tranny afcter clutch install(only rolling from a stop)
Old Apr 27, 2006 | 05:14 PM
BOTTLEDZ28's Avatar
My buddy just installed a SPEC stage 1 clutch in his 96 Z28 and he gets a bad vibration as he lifts off the clutch pedal to get the car rolling from a dead stop. it runs smooth after the clutch pedal is fully released. it doesnt do it as badly while the car is rolling when he shifts to the next gear. its just from a dead stop. this is what I tried already:
engine running, tranny in N pedal out=no vibration
engine running, tranny in N,pedal in= no vibration
engine running, tranny in 1st, pedal in=no vibration
engine running, tranny in 1st, pedal just slightly up=vibration
engine running, tranny in 1st, pedal out, car moving=no vibration
engine running, tranny in ANY gear, pedal slightly up=vibration
Old Apr 28, 2006 | 09:53 AM
OBE1 95Z28's Avatar
Re: bad vibration in tranny afcter clutch install(only rolling from a stop)
I believe you're describing clutch chatter. New clutches can be "grabby" causing the chatter. Some clutches get much smoother after around 500 miles of normal driving. My friend's Spec 3 has always had chatter releasing in first gear, even after 20K miles; all other shifts are fine. My street twin was never grabby.
Old Apr 28, 2006 | 10:30 AM
LS1powerhouse02's Avatar
you are definately experiencing clutch chatter. Specs are particularly bad about it. It will get better after the "break in" period. But specs have always been known for having clutch chatter. one thing i have noticed that helps is not just riding the clutch out to get going, specs hate to be slipped at all. Just give the throttle a little blip and then let the clutch out. See if that helps at all.
Brent
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
