Who installed your headers?
Old Apr 21, 2006 | 02:50 PM
Resilient94LT1's Avatar
Hey everyone,
I'm considering the purchase of Pacesetter MIDs for my 94Z. My search turned out a couple of here and theres, but no real clear procedures and info. Do the majority of you header buyers get your headers professionally installed, or is this something that can be done in your own driveway? I don't have any means of pulling my engine available, so can it be done from beneath the car? Input appreciated, thanks!
Old Apr 21, 2006 | 03:31 PM
BUBBA's Avatar
Re: Who installed your headers?
I suppose, however, the car better be good and high off the ground (and be careful to ensure a solid platform) don't want to hear that you were squished.
Another problem, however, is if you need to work from on top and on the bottom---it can be a real bear. JMHO
Old Apr 21, 2006 | 03:39 PM
luckyou03's Avatar
my shorties come out of the top, but my long tubes went in threw the bottom. Will have about 4-6 hours or so install headers ther first time. I believe most people here install them thereself. Just dont overtorque the header bolts installing them and break the old one coming out and your fine.
Old Apr 21, 2006 | 03:40 PM
mattbailey's Avatar
I did mine, car looked dangerous it was so high. If you have a lift it would be much safer.
Old Apr 21, 2006 | 03:42 PM
6SpdLT1Z's Avatar
Previous owner did mine.
Old Apr 21, 2006 | 03:45 PM
I'd like to do them myself, but i'm doubting I'll have access to a lift... labor charges would be too much of a hassle to think about going that route. How high should the car be off the ground for shorties/mids?
Old Apr 21, 2006 | 04:34 PM
kick Z tail out's Avatar
Did it with a friend who runs a small shop out of his house. He has all the tools one would need, so we did it over there... No lift. Jacked the car up as high as we could get it and started working on it.
It was a PITA and took forever because work stalled out a few times... when we ran into parts that needed to be fabricated or replaced because they didn't jive with new parts. I love my headers though and I'm glad it's over.
Old Apr 21, 2006 | 05:50 PM
guywithaZ's Avatar
I had someone with a lift do mine...it's lowered and and hard to get under, there would have been no way I could have done it on my driveway, it's a tight squeeze just to change the oil
Old Apr 21, 2006 | 07:03 PM
Jeff H's Avatar
I did my longtubes myself in the garage during the coldest period this past winter. The longtubes are a PITA and I had the car jacked up a good 3-4 feet high. The midlength headers shouldn't be as bad but it's still time consuming to remove everything to install the headers from underneath. I would say to plan on the car being down for a week straight while you work on it if it's your first install. You'll run into problems and need tools and need more parts. It's worth it in the end though.
Old Apr 21, 2006 | 07:04 PM
tiznodd's Avatar
I installed a set of Pacesetter mids on my car and it wasn't very difficult. The driver side goes in from the top and the passenger side goes in from the bottom. You would not need to get the car too high off the ground to install mids.
The driver side was cake with the exception of the steering shaft needing to be adjusted slightly to keep it from rubbing. The passenger side was more difficult. You will have to remove the starter, dipstick and alternator support. I also took out the 2 rear plugs to get more clearance between the head and AC box.
Hope that was helpful.
Old Apr 21, 2006 | 07:09 PM
Z95m6's Avatar
I installed my headers on my car. I would stay away from those pacesetter mids everyone says the plug access is 10x worse than stock.
Old Apr 21, 2006 | 07:49 PM
LAB3's Avatar
I live in Ft. Worth Texas I have a 96 LT4 Corvette and want to find a good shop to install a set of Extoic Muscle Long tube 1 3/4 inch headers and install a pair of Randon tech cat's to keep it legal. Any one from my area?
Old Apr 21, 2006 | 07:56 PM
Bud M's Avatar
I did shorties with the car on jackstands in my garage
LAB3, you shoud start your own thread
Old Apr 21, 2006 | 08:10 PM
LAB3's Avatar
Thanks Good idea, I just saw a exhaust post and you never know who is around. I did the shorties on my wifes 96 TA and I only gained 4 HP over stock exhaust manifolds, man I was upset as SLP said I would get 10. Long Tubes is the way to go but a lot more time and money.
Old Apr 21, 2006 | 08:44 PM
robwin95z's Avatar
damn, i must be the luckiest guy in the world. am i the only one who installed both my pacesetter longtubes from the top? both slid right in on my 95 z. i did have to show the passenger side who was boss tho. car wasn't even on the first notch of the jackstand either.
take off the valve covers, that's where the magic's at...................
