94 camaro 94 caprice computer
Old Apr 18, 2006 | 11:49 AM
percylhd's Avatar
I am working on a 94 Camaro with code 43 knock sensor and a bunch of abs codes. This camaro has a computer from a 94 caprice does anyone know if this computer is campatible with a 94 camaro?
Old Apr 18, 2006 | 08:35 PM
Lt1Regal's Avatar
Re: 94 camaro 94 caprice computer
The PCM will work fine....but the caprice has 2 knock sensors. You should be able to swap your old Knock Module from the camaro to get rid of the Knock Code. If you dont have the old one get a Lt4 Module.
Good Luck
Old Apr 19, 2006 | 04:57 PM
percylhd's Avatar
tried that have to get differnt computer
Old Apr 21, 2006 | 08:27 PM
Dave89IROC's Avatar
the computer is the same f-body to b-body, only difference if the knock module and flash(software)
Old Apr 22, 2006 | 12:18 AM
The ABS codes aren't set by the PCM. They come from the EBCM. You don't need a new computer.
Old Apr 23, 2006 | 06:17 PM
percylhd's Avatar
the abs has been repaired since the first post.It was traced to a wire at the connection above the LF wheel sensor.The code 43 knock sensor,was checked out according to the manual.Knock sesor is good so are wires,next is either connection at computer,or computer.The owner of the car insists on putting
in a new computer.Thanks for the info,you can e-mail me if you would like to know what the final fix is
SinisterRacing1
Mar 7, 2015 03:44 PM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
