How do I replace the turn signal lens?
Old Nov 6, 2002 | 02:50 PM
abarus's Avatar
Do I need to remove the front bumper cover, or is there an easier method.
Thanks,
Old Nov 6, 2002 | 04:40 PM
Joshs99BlackBeauty's Avatar
I just did that yesterday. I put the clear turn signals in. I took off the skirt under the front nose, jacked the car up, and took it off that way. That was the hardest thing I have ever done with my car. Its not a problem getting to them or unbolting anything, its getting around that foam in the nose cose. Maybe I did it the wrong way but thats how I did it. You could probably unbolt the headlight and go at it through the top...it might be easier that way.
Old Nov 6, 2002 | 07:23 PM
DARK AGE 53's Avatar
This thread should be of some help, http://www.ls1tech.com/ubb/cgi-bin/u...=002388#000011 .
Al
Old Nov 6, 2002 | 08:56 PM
silver96z28's Avatar
Just take out the headlight, one bolt holds it in, lot esier than doing it from underneath, unless its a LT1 car, do those from the bottom!
Old Nov 6, 2002 | 09:20 PM
ratio411's Avatar
Like stated above... 1 bolt holds the lamp housing in.
It is 10mm and is dead center on the rear of the housing. Unplug the bulbs first! Then remove the bolt. Slide the lamp housing towards the nose of the car, then lift it out. Easy.
Now look down into the hole, the corner lamps are right there for the world to see.
Good luck
Dave
Old Nov 7, 2002 | 01:42 PM
abarus's Avatar
Thanks Everyone! I swapped it out and it was as simple as you all explained it. Thanks Again!
Old Nov 7, 2002 | 05:09 PM
hmm...leave it to me to do it the hard way
stangspank
Nov 13, 2015 01:02 PM
CaRParts102
Dec 6, 2014 08:45 AM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
