Nitrous newb. 75 shot HELP!!
Old Apr 17, 2006 | 10:48 AM
streetheatz28's Avatar
I just got a 1987 z28 that has a tpi 305 with 102k on the clock. The only mods I am planning on doing is exhaust, slp cai, and underdrive pulleys. My question is - Would I be safe to spray a 75 dry shot without a tune? If not what will I need? I don't think i'll spray but a few times a year so its not going to be a every week thing. Thanks - Charlie.
Old Apr 17, 2006 | 12:34 PM
LB9GTA's Avatar
Re: Nitrous newb. 75 shot HELP!!
dry or wet shot?
If dry, make sure your injectors are ohm tested.
If either shot, make sure your fuel pump is up to par.
No problem with the dry shot for me.
Old Apr 17, 2006 | 03:52 PM
2000GTP's Avatar
A 75 shot is a safe jetting to spray. As mentioned above though, it is still a good idea to make sure everything is mechanically sound.
Old Apr 17, 2006 | 06:35 PM
69z-28's Avatar
i would go with a simple nozzle style wet kit. install the kit with a fuel pressure safety switch and a window switch isnt a bad idea either.
Old Apr 17, 2006 | 07:27 PM
LameRandomName's Avatar
Originally Posted by streetheatz28
Would I be safe to spray a 75 dry shot without a tune? - I don't think i'll spray but a few times a year so its not going to be a every week thing.
Fact is, I'm just learning my way around nitrous again. Last time I used it, I had an toggle style arming switch and a button type momentary switch.
As you can imagine, the new technology has got my head spinning.
One thing I know hasn't changed is; it's not how OFTEN you spray, it's HOW you spray.
I'm not sure I'd want to spray 75hp worth of nitrous without at LEAST pulling two degrees timing.
68camaroboltz
Oct 5, 2015 11:56 PM
95blkss
Sep 22, 2015 03:18 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
