car is really really lean at part throttle
Old Apr 16, 2006 | 09:47 PM
creed1062002's Avatar
I have added 8.% to the ve tables and it acts like it is getting worse, am i going the right way, or should i be using a different table?
Old Apr 16, 2006 | 10:20 PM
Re: car is really really lean at part throttle
I know it is lean because the plugs are extremely white on top but down in them it is black, any ideas? They look like that after a 4 mile drive with no WOT. They were brand new.
Old Apr 17, 2006 | 11:15 AM
97WS6Pilot's Avatar
It should not be lean at part throttle. The computer shoots and adjusts for 14.7 in closed loop. I would check it with a wideband as opposed to making decisions based on your spark plugs. 4 miles is not long enough to get an accurate spark plug reading. You probably barely got into closed loop if at all.
Old Apr 17, 2006 | 02:46 PM
that is the second set of plugs in it, that looked like that, the others had probably 5000 miles on them, it is also picking up knock and retarding the timing 9.0 degrees between 1000 and 2500
Old Apr 17, 2006 | 11:14 PM
BeaversTA's Avatar
Try looking at your short and long term fuel trims.
Old Apr 18, 2006 | 09:39 AM
mattbailey's Avatar
Try adding a couple of % to your maf tables in the affected areas.
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
USAirman93
Nov 24, 2014 03:37 PM
one wicked element
Aug 7, 2002 03:11 PM
