Nitto 555 DR 315s at the track
Old Apr 11, 2006 | 04:08 PM
sleeperMULLET's Avatar
hey guys, i ran my car for the first time at the 1/4th, i ran 13.4 @103mph. my 60foot was 2.01, i think i can shave a few 10ths off of it. I used 23lbs of air in the tires and did nice long burnouts and moved up until i heard them squealing, but i still spun all the way through first gear, btw i have an A4. i have the stock T/C so i stalled untill 1200rpm and mashed the gas, i think mashing the gas is part of my problem but it didn't feel like the tires wanted to hook up. Should i remove more pressure? does anyone run these tires or have an suggestions about launching with the stock T/C, shift kit, and 3.73s?
Old Apr 11, 2006 | 04:13 PM
JakeRobb's Avatar
Super Moderator
Re: Nitto 555 DR 315s at the track
I think you should try a shorter burnout. Maybe 3-4 seconds.
Old Apr 11, 2006 | 08:54 PM
AutoRoc's Avatar
All of my Nitto Drags liked a 7-8 second 2nd gear burnout. I ran my 315's at 20PSI. It never hooked on spray but they had no problem going 1.80 with a stock TC in a TPI car with 3.73's. 14 second car also.
Try different burnout lengths, always drive around the water and back into it. I liked to stand on the brake at 1500rpm, let off, roll onto the throttle hard. Let the car transfer a little weight to the rear before full throttle. Remove the front sway bar also! That's a very FREE way to get more front end movement, weight transfer, and reduce weight.
Mar 13, 2016 03:37 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
