OBD1 vs OBD2 - What would happen?
Old Apr 7, 2006 | 09:39 AM
mitchntx's Avatar
A little background ...
I have a '95 Z28 that I have built for road racing.
It has an LT1 motor and 6 speed.
The wiring harness has been completely removed and a bare bones Painless harness has been installed in it's place.
All that the car has is engine management. No trans, no fans, no EGR, no VSS ... just AIT, MAF, coil, throttle body, injectors, fuel pump ...
The car has no key ... it's on a toggle switch to apply power to the PCM, coil and injectors and a momentary toggle to enegize a starter solenoid.
So, when I say basic, I mean basic ...
My question ...
Would any LT1 sequential fire PCM work in this case, regardless of OBD1 or OBD 2?
Old Apr 9, 2006 | 07:19 AM
mitchntx's Avatar
Re: OBD1 vs OBD2 - What would happen?
Surely this isn't new territory ....
Old Apr 9, 2006 | 02:30 PM
Dave '97 Z28 M6's Avatar
An OBDII PCM will be looking for the Crankshaft Position Sensor, which doesn't exist on the OBDI cars. Also the knock sensor is different between I and II. To make it easy, I'd suggest just using an OBDI PCM. But, doubtlessly, those 2 problems I mentioned are not insurmountable.
Old Apr 9, 2006 | 09:12 PM
mitchntx's Avatar
Thanks for the input ...
w/o a CPS, will it just throw a code? For 96 at least, the PCM was just looking at the CPS for misfires, as I understand it. No operability issues ...
And if I install a "287" knock module, that should make all the little electrons happy, right?
The reason I'm asking is I have a shelf full of OBD2 PCMs and a single, suspect OBD 1 PCM. It went through a car fire. The wiring leading to the PCM was melted, but the connectors themselves were sooty, but not melted. There were no signs of damage external.
But who knows what happened inside that metal box. ...
Old Apr 12, 2006 | 10:42 AM
mitchntx's Avatar
So, based upon this response ...
http://web.camaross.com/forums/showthread.php?t=444363
There should be no driveability problems. Maybe a few codes, but no engine performance issues.
Correct?
Old Apr 17, 2006 | 07:50 AM
mitchntx's Avatar
Well, it appears to work just fine ...
Old Apr 17, 2006 | 09:53 AM
Sorry I didn't get back to you... I was away from the board for a few days. Glad to hear everything worked out for ya.
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
