#'s to expect
Old Apr 1, 2006 | 02:55 PM
Musclehead87's Avatar
#'s to expect
Hey guys. I'm leaning towards an 98-02 SS. Just need some advice first.
Let's say the SS is BONE STOCK. What RWHP should i be expecting with these mods..
1. SLP cold air intake
2. SLP loud mouth 1
3. Y pipe off road
4. Headers (anybody know a good make for them?)
thanks guys
Old Apr 1, 2006 | 03:35 PM
camaro_five0's Avatar
Re: #'s to expect
well the 98-01 SS has the LS1 intake, while the 02 SS came stock with the LS6 intake. This adds a little HP. I dont know how much but is is a difference. With those bolt-ons you're PROBABLY looking at 340-350 HP (in an 02).
Old Apr 1, 2006 | 04:13 PM
Re: #'s to expect
damn that's pretty good. thanks a lot man
Old Apr 1, 2006 | 06:57 PM
GhostZ28's Avatar
Re: #'s to expect
more like 340 ish, or lower. you're very capable of much more (360), with a good tune.
99+ have bigger injectors, 99's have the biggest cam, and some 01-02 came with LS6 blocks! your choice. the newer versions also have basicaly shorty header exhaust manifolds. LS1=LS1 some naturally dyno higher, some lower. the deciding factor should be what the best deal is and whats been best cared for.
Old Apr 1, 2006 | 07:32 PM
SSpdDmon's Avatar
Re: #'s to expect
Whoa guys...knowledge base is slipping in this thread. 99's had the smaller injectors (26#ers), 01's had the LS6 intake too (not just 02's) and true some of the last f-bodies came with an LS6 block...but that won't improve performance.
If you get an M6 with those mods, then you're looking at mid 340's for rwhp. A tune could net you another 10hp or so. An auto will drop you 10hp or so....but they are great when you add an aftermarket converter. I expect mid to low 12's with the mods you've listed plus a converter/gears, which isn't bad at all considering the car went ~13.3 bone stock.
Old Apr 1, 2006 | 07:58 PM
cbrakllr88's Avatar
Re: #'s to expect
They started putting the LS6 intake on 2001 and up.
Old Apr 1, 2006 | 08:57 PM
MonkeyBoneSS's Avatar
Re: #'s to expect
i was under the beliefe that only a few SS or Z28's had the LS6 in them. They were put in there by mistake, so they claim!!
Old Apr 2, 2006 | 07:53 AM
AL SS590 M6's Avatar
Re: #'s to expect
LS6 BLOCK not LS6 motor and it wan't by mistake.
Old Apr 2, 2006 | 08:23 AM
Re: #'s to expect
wow. nice numbers. thanks a bunch guys!
Old Apr 3, 2006 | 12:10 AM
GhostZ28's Avatar
Re: #'s to expect
ya i couldnt remember the injector sizes, i thought the 99 and up years had bigger ones, but i figured someone would correct me!
Old Apr 3, 2006 | 07:05 AM
scottslt1z28's Avatar
Re: #'s to expect
wow knowledge is slipping..............as stated earlier........99's had the smallest injectors
98's had the LARGEST injectors and the MOST Aggresive cam of all the years. Yet the later versions 01-02 made more power simply because of the ls6 intake manifold and the ls6 exhaust manifolds.
The block has no real significance in power. There were a few other things that distinguish the 98 f-bodies from the 99-00 and 01-02, however i noted the large ones above. Search and find out which year/car is better for what you want to do.
--Scott
Old Apr 3, 2006 | 10:18 AM
Re: #'s to expect
--Scott
yeah i am doing some research. And you guys are helping me a lot to. I really do appeciate it and all. What i plan doing to my next car is running it on all motor.. possibly no forced induction, ever. haha. So, i'm deciding on what camaro ss (98-02) that would provide good power and will respond the best to mods. I'll check out the 98 about the huge cams and big injectors. THanks guys
Old Apr 3, 2006 | 11:09 AM
cabell84's Avatar
Re: #'s to expect
Don't get the wrong idea, the cam is hot HUGE by any means, just a little more agressive, same goes for the injectors.
Old Apr 3, 2006 | 11:56 AM
NiteRider's Avatar
Re: #'s to expect
--Scott
2000's had improved exh manifolds as well.
Old Apr 4, 2006 | 12:05 AM
GhostZ28's Avatar
Re: #'s to expect
i was PRETTY sure the 99's had the slightly larger cam, i remember because i was excited i picked the year with it. I jsut tried to search for the tread from about a month or 2 ago that was alot about this stuff, and cant find it. does anyone have a link to it.
